Sprytny
posted on 17/4/10 at 10:00 PM |
Idle control valves
On removing a throttle control valve, I didn't replace the gasket. Would I be wrong in appling a smeer of copper ease around the
gasket on re-application? I torqued the bolts correctly. Also, can WD40 be used as an alternative to carb spray in cleaning out the valve, or may this
cause more problems? Thanks guys again. Greg
big_wasa
posted on 17/4/10 at 10:42 PM |
I wouldnt use grease. Either a very light smear of instant gasket or make a new gasket from gaskt paper.
Davegtst
posted on 18/4/10 at 07:32 AM |
WD40 won't do anything to clean it out, get some carb cleaner. As above don't use grease, get something like hylomar blue.
mad4x4
posted on 18/4/10 at 12:39 PM |
Don't use grease use something like this
Linky Click
orLinky Click
[Edited on 18/404/10 by mad4x4]
Scot's do it better in Kilts.
