Author: Subject: Vw beetle airbag sensor replacement question
Stott
posted on 3/8/13 at 01:43 PM Reply With Quote
The mrs has an 04 1.4 beetle cab, the airbag light is on.
Scanned with vag com and its the o/s front crash sensor implausible:intermittent signal, apparently a common fault.
What I want to know is if I change the sensor will it need coding to the car or is it just a case of resetting the light?
I've got access to a snap on scanner so I can erase the code but didn't know if anything else needed doing.
Anyone know?
Cheers!
rhinopower
posted on 3/8/13 at 05:52 PM Reply With Quote
Replace and reset
Stott
posted on 3/8/13 at 09:57 PM Reply With Quote
Thanks, that's what I wanted to hear!
