Author: Subject: scratch build with new reg please
Julian B
posted on 27/4/16 at 07:57 PM Reply With Quote
Hi Guys
I'm thinking of a new scratch build and I would like a new registration
My plans are these
Buy a Lexus v8 and strip it of its engine keep the v5 but sell the rest for wonga
Buy a supra gearbox for it
Use Sierra bits for the axles and brakes
Possibly use a freelander diff
What's the score with this bag of bits. Am I heading into Q land
Let's assume that all bits other than the engine are new or have invoices from manufacturers to say they are "as new "
kingster996
posted on 27/4/16 at 08:10 PM Reply With Quote
Strictly speaking for a new reg every single part except one "reconditioned to as new" part must be brand new.
For an age related plate you need a few major components such as engine gearbox drivetrain to quality and the v5.
Otherwise it's s Q.
Many people manage to buy new parts from Microsoft Word.
I used to be indecisive, but now I'm not so sure
z2000
posted on 27/4/16 at 08:11 PM Reply With Quote
I'm prepared to be corrected but if everything is *new* except one major component (engine in your case) then I believe you could get a new reg.
If it isn't broken; take it apart and fix it! Build PhotoBlog:
http://z2000.co.uk
leew2
posted on 27/4/16 at 08:33 PM Reply With Quote
Am I correct thinking only the "major components" have to be brand new, or does every single last nut and bolt have to also be "new" with receipts?
tegwin
posted on 27/4/16 at 09:16 PM Reply With Quote
As an asside... does a 'new' reg kit car have to comply with new emissions standards?
If its an old engine wouldn't it be better to have it tested by the standards to which it was intended?
www.verticalhorizonsmedia.tv
benjo
posted on 27/4/16 at 09:18 PM Reply With Quote
PMSL wonder how true that is
kingster996
posted on 27/4/16 at 09:42 PM Reply With Quote
Technically yes, but they only ask for major components plus some evidence of the one refurbished item.
So, technically, there should be very, very few new registrations as many, many cars use refurbished diffs and gearboxes even if they have a crate engine. I mean can you even buy a new Sierra diff?
[Edited on 27/4/16 by kingster996]
loggyboy
posted on 27/4/16 at 09:44 PM Reply With Quote
Its based on engine age (design age)
Mistral Motorsport
kingster996
posted on 27/4/16 at 09:45 PM Reply With Quote
Emissions go with age of engine. So you could use new bits and a refurbished 1993 engine and not need a cat for example.
tegwin
posted on 27/4/16 at 09:48 PM Reply With Quote
Ahh that makes more sense!
loggyboy
posted on 27/4/16 at 09:50 PM Reply With Quote
So, technically, there should be very, very few new registrations as many, many cars use refurbished different and gearboxes even if they have a crate engine. I mean can you even buy a new Sierra diff?
But the list of new components checked is:
- Chassis / Monocoque
- suspension (front and back)
- Axles (both)
- Transmission
- Steering Assembly
- Engine
Meaning Gearbox and Diff are both classed as one component - so can both be refurbed.
This is where BECs can struggle as gearbox and engines are often physically combined, but can be classed as 2 components for registration, so you cant just refurb the bikes engine to as new.
TO answer OPs question, no you coudnt have a new reg based on what you propose, but you could easily retain the age of the donor (meaning no Q stigma (amongst uninformed), and personalised reg options) - which is about the only benefits of a donor age over a Q plate.
Mistral Motorsport
kingster996
posted on 27/4/16 at 10:04 PM Reply With Quote
Good call on the transmission, but many use a refurbished engine and somehow have a "new" type 9 and Sierra diff
I deliberately applied for a Q. Much better in my opinion (future mots a doddle and tune the engine for power, ageless too)
