Removing bitumen from a tyre
Mr Whippy - 7/7/20 at 11:49 AM
Seems I drove over some very soft bitumen on the road which has covered half the tyre and is proving a total nightmare as stones are sticking to it and it's putting the whole wheel out of balance making the car shake. I've tried scraping it off but it's so difficult. Any ideas how to deal with it without wreaking the tyre???
thanks
StrikerChris - 7/7/20 at 01:06 PM
Probably sounds worse than it is. A good thrash down a muddy road?
James - 7/7/20 at 01:19 PM
Remember that old trick for getting candle wax out of carpets? Put kitchen paper over it and iron it- the liquid wax is absorbed into the paper.
I wonder if you could do something similar with towelling and a (very!) old iron?
Or other heat source but an iron would seem an easy/cheap to source one.
Let us know how you get on!
James
steve m - 7/7/20 at 03:14 PM
White spirit takes bituemen off body work, as does petrol,
so immersing the tyre into a large bowl ?
what about a pressure washer to get most of it off?
Benzine - 7/7/20 at 03:40 PM
Originally posted by James
(very!) old iron?
Any old iron!
nick205 - 7/7/20 at 04:19 PM
How old are the tyres?
How close to renewal time are they?
SWMBOs car recently got a puncture, which annoyed me at first. The car has no spare wheel so after pulling a nail out I had to fill the tyre with gloop, inflate and then replace the tyre. In the end I replaced both front tyres as they were a month or two away from needing to be replaced anyway.
Mr Whippy - 7/7/20 at 04:19 PM
Yeah this is like 1/2 inch thick right across the full width of half a side, with stones pressed into it I don't think a paper towel is going to cut it. I've tried a wood chisel and been at more risk of puncturing the tyre. I'm not keen on using any spirts or petrol as that may affect the rubber...
Slater - 7/7/20 at 04:28 PM
Fit the wheel to your driven axle then do some nice wheelspins, burnouts etc. that should scrape it off.
James - 7/7/20 at 05:14 PM
1/2"? Did you drive down a road they were still laying tarmac on?
Would The Tool (carefully applied not to damage the tread!) do it?
sonic - 7/7/20 at 05:47 PM
Contact the council and make a complaint, i drove down a road recently with no warning signs and no way of avoiding pot holes that had just been filled in.
my tyres were covered and then loads of chippings stuck to them, i took loads of pictures also showing my car body work peppered with black dots.
sent it to council and they told me to get two quotes to put it right and they would pay the bill.
Mick
Daf - 7/7/20 at 05:59 PM
What about pouring boiling water over it to soften then trying scraping?
JMW - 7/7/20 at 06:06 PM
Or a heat gun?
sebastiaan - 8/7/20 at 06:28 AM
heat gun + scraper. Similar to taking pickup / marbles off slick tires. Hard work.
russbost - 8/7/20 at 07:15 AM
You can use any solvent on it you like TTBOMK there is no solvent on earth that will affect a rubber tyre, hence why they have become such a disposal nightmare as you can't even melt the tyre down in any ordinary way
I would have thought heat gun & scraper followed by old rag soaked in petrol or thinners - don't combine the heatgun with this!
Alternatively get it up to 150 mph, i'm sure the centrifugal force will remove it for you!
coyoteboy - 8/7/20 at 11:57 AM
As above, petrol and a cloth/toothbrush, it's a minor inconvenience at most.
rusty nuts - 8/7/20 at 01:45 PM
Diesel doesn’t do tyres any good!
If your going to use a solvent use Bufsol , made for tyres , ask your local tyre dealers if they can get you some
russbost - 8/7/20 at 01:50 PM
Diesel will have no effect on the structure of the rubber - just makes it slippery until it's burnt/worn off
rusty nuts - 8/7/20 at 05:23 PM
Try soaking a tyre with diesel and see what happens!
russbost - 8/7/20 at 05:38 PM
Hmmm, interesting, I've always understood that modern tyre compounds were totally impervious to virtually any chemical attack, hence my comment about why they are such a pain to recycle. Surely if diesel actually gets "into" the compound & softens it then leaving tyres soaking in diesel would bring about their eventual destruction & carcasses could be easily separated from the rubber. Tried googling & found plenty of "urban myth" stories about diesel softening rubber, but can't find anything from anyone with qualifications.
I would have expected that soaking in diesel would do nothing more than dissolve crap off the outside of the tyre rubber giving you (possibly) temporary additional grip until the diesel had burnt/rubbed off
My understanding has always been that the only way to break the tyre compounds down to anything useful is the pyrolytic conversion at very high temperatures - apparently they can actually turn tyres back into fuel that way - not a very efficient process I would imagine
Quite happy to stand corrected, but would be interesting to see anything like a uni study, or scientific paper on it
coyoteboy - 8/7/20 at 06:04 PM
Diesel or petrol won't harm the tyre as you'll clean it straight back off again. It's vulcanised, sure those hydrocarbons are solvents and will soften it over time, but when we talk about oil damaging rubber we're normally talking about things like hoses and o-rings and over years with heat. Not from a quick wipe down with a wet rag and a clean off.
If it was, you'd be replacing tyres every few months due to contamination at fuel stations...
skippad - 9/7/20 at 08:29 AM
Cellulous thinners or tar remover (5ltr tin) and elbow grease will get off ...but wont be a 5min job.
Patience needed!!
indykid - 9/7/20 at 09:34 AM
Chest freezer? Pipe freeze spray?
Chill it down and crack it off?
jacko - 9/7/20 at 07:23 PM
Buy a new tyre greedy burger😎😎😏
Jacko
