Author: Subject: Bailey Performance - Here to Help!
BaileyPerformance
posted on 11/1/18 at 02:13 PM Reply With Quote
Hi Folks,
Not posted for ages so i thought i'd say hello and remind everyone of our services.
We map almost all aftermarket ECUs on our in-house 2WD dyno, just mapping accounts for about 50% of our work, but you maybe unaware we also offer turnkey MS installs too - the whole job - supply,fit and map. (takes the headache out of any kit car build)
We are also doing more and more forced induction conversions, again we can offer turnkey Turbo / SC conversions for X-flows to Hayabusa's and most engines between. We are working on an ECOBOOST at the moment, ironing out the know issues with the engine and converting to port injection (to allow the use of the popular ECUs such as MS, OMEX, DTA, Emerald)
Worth also pointing out we get several cars a month that arrive for mapping on a trailer, some will sort of run, some have no life at all, we are happy to work with the customer to get the car running and mapped so your project does not need to drive or start.
So far this week we have mapped a Triumph Stag on Emerald fitted with a Cosworth 24v V6 twin turbo 409HP
A turbo charged MX5 1600 on Megasquirt 210HP
An Escort S2 RS Turbo 2.0L ZVH on Megasquirt 237HP
Please PM or email if we can be of help.
Cheers Dale.
www.facebook.com/baileyperformance
www.baileyperformance.co.uk
dale@baileyperformance.co.uk
jossey
posted on 11/1/18 at 08:56 PM Reply With Quote
Having previously been ripped off by 3 kit car companies including damaged paintwork. Charged for work not completed. Engine installs in dangerous ways. I got recommended to try these guys. Although they are a 8 hour round trip I thought I would get some engine work done.
All I can say is wow a company who are professional and offered after sales support when needed. Great work completed and they spotted and repaired other issues they found nothing to do with the work being complete. Also bought me a sandwich when there for the full day.
I would drive to these guys again. I live near Skipton North Yorkshire so not close by but hell was the best company I've dealt with who really understands kit cars.
David Johnson
big-vee-twin
posted on 12/1/18 at 05:28 PM Reply With Quote
Agree with Jossey.
Dale installed and tuned my Jenvey throttle bodies with dual fuel injection system, then tuned it, including transporting to and from his workshop.
http://www.triangleltd.com
BaileyPerformance
posted on 5/2/18 at 04:03 PM Reply With Quote
Thanks for your kind works guys, glad your happy.
Cheers Dale
r1_pete
posted on 6/2/18 at 01:10 PM Reply With Quote
Hoping to get the cold start and idle sorted on this so I can get it over to you for tuning.
944 V8 done
944 V8 done
BaileyPerformance
posted on 6/2/18 at 05:19 PM Reply With Quote
944 V8 done
944 V8 done
Dont worry, we'll sort idle and cold start here.
We use 1.8/2.0 Zetec idle valves on RV8s, 2 wire, work great. Just need to make i little plate up to allow connection of pipes.
Cheers Dale
r1_pete
posted on 6/2/18 at 06:31 PM Reply With Quote
Cheers, Ive fitted a 2 wire bosch unit, feeding each plenum from the back, I just need to figure which settings to use, I think I ned closed loop, and then set the decay in pwm idle settings....
2 wire bosch
2 wire bosch
BaileyPerformance
posted on 7/2/18 at 10:03 AM Reply With Quote
2 wire bosch
2 wire bosch
I could never get the Bosch to work properly on PWM, i used a resistor and capacitor to form a charge/pump circuit to feed the Bosch with DC voltage in relation to PWN duty.
Your best bet is to bin the Bosch and fit a Zetec valve which works far better.
Cheers Dale
gaz_gaz
posted on 16/1/19 at 06:25 PM Reply With Quote
Dale, I've dropped you a message U2U
BaileyPerformance
posted on 17/1/19 at 10:35 AM Reply With Quote
Hi, just replied :-)
