Anyone with a 2ltr Pinto and Bosch Dizzy
Avoneer - 24/4/04 at 11:59 AM
Calling all members running a 2ltr Pinto with a Bosch electonic dizzy and the little black box - help.
Does anyone have any diagrams as I may be confused. I know there are 3 different black boxes and a few dizzys and need to get it right. I have had the thing running, but also had some bolts of lightning from the coil.My black box is of the 83BB12A199B51 variety and I have the Bosch electronic dizzy.
Pat.....
bob - 24/4/04 at 05:46 PM
Pat
I'm running a bosch single vac transit dizzy with the transit amp/module,ign module has 6 working wires and are as follows.
BROWN = earth
ORANGE = dizzy
VIOLET = dizzy
WHITE = Switched 12V +ve (small spade on starter motror)
BLACK = +ve on coil
GREEN = - ve on coil
White was the wire that confused me as was told some people do not use it,and some people said join it with black wire which confused m even more.
I hope this helps in some way,but i'm sure plenty of others will contribute.
if in doubt do a search on pinto amp module wiring.
bob - 24/4/04 at 06:36 PM
it got the better of me,so i popped out into the garage to have a look and check the wiring.
I didnt use the white wire on the module/amp,rest is as previous post
Jimbo - 9/5/04 at 09:51 PM
check here!
