Mounting a coil pack
ian.stewart - 27/5/17 at 08:33 AM
In my quest for keeping my engine bay neat n tidy, is there any problem mounting my coilpack to the block, probably on rubber isolator blocks,
40inches - 27/5/17 at 08:53 AM
I fixed mine to a bracket mounted on the top of the bell housing, it's still there
r1_pete - 27/5/17 at 10:33 AM
Mines bolted to a plate on a dummy distributor fitting, so same as, on the block, its fine.
HowardB - 27/5/17 at 12:55 PM
Zetec engines have the coils on a bracket on the back of the block,. hth
lsdweb - 27/5/17 at 04:58 PM
Standard on a lot of French cars although probably not the best example of reliability :-)
big-vee-twin - 28/5/17 at 12:14 PM
On my Duratec Ford bolt the coil pack directly to the rear of the head.
