Author: Subject: Rover V8 earth strap
paulc
posted on 12/4/18 at 11:36 PM Reply With Quote
In the process of sorting out my engine wiring. Its a 1996 Hotwire EFI if that helps.
Where should the earth strap to the chassis go?
Theres an earth point at the front below the alternator.
Another one on the back of the passenger side cylinder head (this is very close to the battery)
Or to a belhousing bolt near the starter?
I'll russel up some pictures tomorrow.
Paul
40inches
posted on 13/4/18 at 09:06 AM Reply With Quote
Use them all, you can't have to many engine earths
907
posted on 13/4/18 at 10:15 AM Reply With Quote
What like throttle cable, choke cable, stuff like that.
Tee he, only kidding.
On a more serious note:-
I have welding lead cable from, Q.R. battery connection to, m8 boss welded into chassis, to bell housing / engine bolt.
Paul G
posted on 13/4/18 at 10:57 AM Reply With Quote
From memory I used a braided earth lead with crimped on ring teminals between my Pinto and Indy chassis. Just the one earth connection seemed to work fine for me. A second connection wouldn't hurt though - if one fails you've got the other there.
paulc
posted on 13/4/18 at 11:06 PM Reply With Quote
Hmmm, souds like all of the above it is then
