Author: Subject: Sierra Indicator Stalk Replacement
Paul27
posted on 11/11/20 at 09:03 AM Reply With Quote
I have a faulty indicator stalk on my Fisher Fury and I am having difficulty in sourcing a replacement.
The stalk is from a Sierra and has integral hazard warning switch so ideally I would like a direct replacement but they are difficult to get hold of. Can anybody suggest an easily sourced alternative that would fit the existing column?
Many thanks
Paul
Mr Whippy
posted on 11/11/20 at 11:22 AM Reply With Quote
there's one here but not cheap
ebay linky
SteveWalker
posted on 11/11/20 at 11:38 AM Reply With Quote
Be careful. Check whether it is a mk1 stalk (square hazard switch) or mk2 (round). The mk1 switches things directly, while the mk2 is designed for intervening relays and pin-outs/switching are different (IIRC). Oh and the mk1 has the horn push, while the mk2 doesn't (again IIRC).
[Edited on 11/11/20 by SteveWalker]
Paul27
posted on 11/11/20 at 01:48 PM Reply With Quote
Thanks, I will make a note of that, definitely the Mk1 that is required
jps
posted on 11/11/20 at 02:56 PM Reply With Quote
There is a Sierra breakers up in the North East - Sierras R US i think? Might be worth trying them, I would have thought Mk1 parts will be rarer.
Paul27
posted on 11/11/20 at 02:59 PM Reply With Quote
Thanks I will give them a try, the MK1 is indeed rare and going for silly money on e bay!
sonic
posted on 14/11/20 at 07:29 PM Reply With Quote
I have a Mk2 one I think, it has round hazard button but no horn. Don't know if you can convert it. Same fitting etc
Paul27
posted on 15/11/20 at 08:25 AM Reply With Quote
Hi thanks, ideally the MK1 which would be a direct replacement.
If I cannot source one either will either have to use a mk2 or fit a separate hazard warning flasher switch and relay because the flasher unit on the Mk1 that is fitted does not work. Both mods would require dash removal and wiring mods so I will continue to look for a Mk1 for the time being.
Many thanks
Paul
posted on 15/11/20 at 08:44 AM Reply With Quote
I have one or two Sierra indicators , I will check to see if I have any mk1 types over the next few days. Have you tried giving you switch a squirt of WD40 ?
Paul27
posted on 15/11/20 at 09:11 AM Reply With Quote
Thanks, yes tried WD40 and contact cleaner.
mangogrooveworkshop
posted on 15/11/20 at 03:02 PM Reply With Quote
PUG 106 works fantastically
If you're still struggling drop me a line
Paul27
posted on 17/11/20 at 09:52 AM Reply With Quote
Ok will have a look, many thanks.
