Author: Subject: mx5 handbrake cable
flange nut
posted on 29/7/18 at 10:54 PM Reply With Quote
mx5 handbrake cable
Hi
I've been test fitting my rear calipers on my mx5 build and I'm rather concerned that the handbrake cable has a very sharp bend after the caliper bracket and from the pictures I've seen is rubbing on the chassis. What have people done to stop this?
Thanks.
Geoff
Slimy38
posted on 30/7/18 at 05:57 AM Reply With Quote
Not sure if it's done to prevent problems with the handbrake, but I have seen several cars running the MX5 rear hubs backwards compared to the MX5. I'm doing it because it suits the suspension set up better, but it might allow better cable routing as a consequence.
chris_smith
posted on 30/7/18 at 06:30 PM Reply With Quote
You need to cut the bracket that comes off the Caliper, shorten and re-weld or thatís what I did on my Haynes build and have seen others doing similar Iíll try and find a better pic
chris_smith
posted on 30/7/18 at 06:45 PM Reply With Quote
Stots build on Haynes forum shows them on page 23
