tintop air con
theconrodkid - 19/4/14 at 02:36 PM
so i splashed out on a newis tintop,the aircon is a bit limp so i am guessing a re-gas is in order also the outside temp gauge is not working,could this effect the aircon ?.
and finally,has anyone used the quikfit type places for a re-gas or should i try and fin a specialist ?.
Ben_Copeland - 19/4/14 at 02:58 PM
Yes, I believe some aircons take readings from inside, outside, and light sensor on the dash.
big_wasa - 19/4/14 at 03:01 PM
I took mine into quick fit last year, only place that I could find with out booking it in. They found a leak so no charge but I was happy with the service. They got me some glasses and showed me the leak under the uv.
Brook_lands - 19/4/14 at 03:40 PM
Kwik fit et al are a bit expensive at around £50 but do honour their cooler or you don't pay offer.
Indies can be cheaper, best round here are about £30 but if there is a problem with your system you still pay.
If the aircon is cooling a bit then it is probably a recharge, if it's not cooling at all then a bit more investigation is required.
The auto fill machines do do a leak test but just because it passes does not mean your system is leak free, it just means its not a very big leak.
[Edited on 19/4/14 by Brook_lands]
big_wasa - 19/4/14 at 03:43 PM
Yes mine passed the pull down test but still had a leak.
theconrodkid - 19/4/14 at 06:44 PM
cheers peeps,looks like a trip to ti fit then
britishtrident - 19/4/14 at 07:22 PM
Check the radiator fan comes on when you switch on the AC
Also if your car has climate control rather than simple AC then usually the ambient air sensor and a sunlight sensor are part of the system.
The climate control units BMW use (also Range Roverand Rover 75 ) have self diagnostic via pressing a button combination at start up.
[Edited on 19/4/14 by britishtrident]
theconrodkid - 20/4/14 at 06:21 AM
BT,it,s a hyundai i 20 if you know about such beasts
