Author: Subject: tintop air con
theconrodkid
posted on 19/4/14 at 02:36 PM Reply With Quote
tintop air con
so i splashed out on a newis tintop,the aircon is a bit limp so i am guessing a re-gas is in order also the outside temp gauge is not working,could this effect the aircon ?.
and finally,has anyone used the quikfit type places for a re-gas or should i try and fin a specialist ?.
who cares who wins
pass the pork pies
Ben_Copeland
posted on 19/4/14 at 02:58 PM Reply With Quote
Yes, I believe some aircons take readings from inside, outside, and light sensor on the dash.
Ben
Locost Map on Google Maps
Enter Your Details Here
big_wasa
posted on 19/4/14 at 03:01 PM Reply With Quote
I took mine into quick fit last year, only place that I could find with out booking it in. They found a leak so no charge but I was happy with the service. They got me some glasses and showed me the leak under the uv.
Brook_lands
posted on 19/4/14 at 03:40 PM Reply With Quote
Kwik fit et al are a bit expensive at around £50 but do honour their cooler or you don't pay offer.
Indies can be cheaper, best round here are about £30 but if there is a problem with your system you still pay.
If the aircon is cooling a bit then it is probably a recharge, if it's not cooling at all then a bit more investigation is required.
The auto fill machines do do a leak test but just because it passes does not mean your system is leak free, it just means its not a very big leak.
[Edited on 19/4/14 by Brook_lands]
big_wasa
posted on 19/4/14 at 03:43 PM Reply With Quote
Yes mine passed the pull down test but still had a leak.
theconrodkid
posted on 19/4/14 at 06:44 PM Reply With Quote
cheers peeps,looks like a trip to ti fit then
who cares who wins
pass the pork pies
posted on 19/4/14 at 07:22 PM Reply With Quote
Check the radiator fan comes on when you switch on the AC
Also if your car has climate control rather than simple AC then usually the ambient air sensor and a sunlight sensor are part of the system.
The climate control units BMW use (also Range Roverand Rover 75 ) have self diagnostic via pressing a button combination at start up.
[Edited on 19/4/14 by britishtrident]
theconrodkid
posted on 20/4/14 at 06:21 AM Reply With Quote
BT,it,s a hyundai i 20 if you know about such beasts
who cares who wins
pass the pork pies
