Author: Subject: Proper Polybush Grease source?
posted on 21/8/14 at 01:02 PM Reply With Quote
I having got ripped off in the past into buying low quality after market void bushes I am about to rebush the on of one of our Rover 75 using polybushes bought off a Bulgarian seller on eBay .
The two part design is a hard poly inner bush running directly in a softer outer bush.
More than enough grease was supplied to grease the bush but looking at the design I would like to modify it by drilling the outer steel housing and outer bush to take a grease nipple, but I don't know where to source enough of the puka polybush grease at a fair price.
[img] MG-Rover Poly Bush
MG-Rover Poly Bush
[/img]
steve m
posted on 21/8/14 at 01:56 PM Reply With Quote
If you "BT" cant find something like grease, how the blazes are we going to survive ??
jacko
posted on 21/8/14 at 03:42 PM Reply With Quote
http://www.millersoils.co.uk/product-list.asp?let=D
Any of these any good for you ?
Jacko
dinosaurjuice
posted on 21/8/14 at 03:55 PM Reply With Quote
I think red rubber grease is what your after, it doesn't do anything nasty to rubber components.
Some types of silicone grease might be ok too.
40inches
posted on 21/8/14 at 04:08 PM Reply With Quote
PowerFlex recommend Copper grease http://www.powerflex.co.uk/road-series/fitting-guides Bottom of article.
And so does this discusion http://www.locostbuilders.co.uk/viewthread.php?tid=103584
Mmmmmm!
rdodger
posted on 21/8/14 at 04:41 PM Reply With Quote
Yes Powerflex come with copper grease.
pewe
posted on 21/8/14 at 06:01 PM Reply With Quote
I use Smith & Allan. for all my oil and grease requirements.
Fully synth 5w-40 20 litres @ £3/litre.
Rubber grease @ just under £5 for 500g.
HTH.
Cheers Pewe10
