Author: Subject: Covering VIN number
phelpsa
posted on 8/8/16 at 11:17 AM Reply With Quote
Covering VIN number
What reason would someone have for covering the visible vin number on their car? This is assuming that the concealed vin number adds up with the rest.
My thought was that someone has run the car on incorrect plates previously and didn't want the number being checked easily. Any more legitimate reasons?
Mr Whippy
posted on 8/8/16 at 11:27 AM Reply With Quote
you really need to ask?
I'd have thought this was an MOT fail point anyway...
[Edited on 8/8/16 by Mr Whippy]
phelpsa
posted on 8/8/16 at 11:28 AM Reply With Quote
Enlighten me. I've never bothered covering mine.
[Edited on 8-8-16 by phelpsa]
Mr Whippy
posted on 8/8/16 at 11:30 AM Reply With Quote
Enlighten me.
the point is there is no reason at all for someone to do that other an something fishy
phelpsa
Say it has 4 numbers, but only the one visible on the windscreen is covered.
phelpsa
posted on 8/8/16 at 11:32 AM Reply With Quote
Enlighten me.
As you can tell from my post, that was my thought. Windscreen replacement man says it is a common occurrence even with legit cars, but why?
Mr Whippy
posted on 8/8/16 at 11:35 AM Reply With Quote
the vin plate i.e. the one with the weights etc is meant to be in the engine bay. The chassis number could be anywhere, sometimes under the carpet on production cars or somewhere you can see it without taking the car apart. Some modern cars have the vin number or chassis number also under the windscreen glass so you can see it from the outside. You don't give much details of this car, does it have a plate in the engine bay? the one on the windscreen isn't mandatory.
phelpsa
posted on 8/8/16 at 11:37 AM Reply With Quote
Its a hypothetical from chatting with the guy that changed my windscreen. He has seen cars where the single VIN number that is accessible without the key (on the windscreen) is concealed. The rest add up with the docs. Always fishy, or is there a 'tin foil hat' explanation as to why people do it?
Mr Whippy
posted on 8/8/16 at 11:40 AM Reply With Quote
I suppose with replacement parts the chances of every windscreen perfectly lining up with a very small factory vin plate would be quite low, especially when a replacement is fitted by hand. I'd not be concerned at all about that tbh. Especially if all the visible number match the engine bay plate. A few cars have the vin number just riveted on to the dash top so not really a very good deterrent to ringing cars, it might actually be a factory production tracking thing or when at dealers before a car gets a reg number
phelpsa
posted on 8/8/16 at 11:42 AM Reply With Quote
I was checking that I could still see the vin number with the new screen. He says that he's come across a lot of cars that have had them purposefully concealed with a piece of paper or marker pen over the inside of the screen. But why?
Mr Whippy
posted on 8/8/16 at 11:46 AM Reply With Quote
the answer is on the web -
Toprivetguns
posted on 8/8/16 at 12:07 PM Reply With Quote
It sounds like a silly reason, however parking tickets tend to slide down the dashboard and cover the VIN.
Only drive as fast as your angel can fly... !
phelpsa
posted on 8/8/16 at 12:08 PM Reply With Quote
Plausible but too farfetched to be common practice?
adithorp
posted on 8/8/16 at 12:30 PM Reply With Quote
I see loads of cars where a pay+display ticket (old tax disc) has slipped down and covered it.
http://jpsc.org.uk/forum/
907
posted on 8/8/16 at 01:15 PM Reply With Quote
With so many cars being cloned nowadays I can understand keeping numbers "out of sight."
Take number plates for instance. Loads of people obscure the number in photo's.
Lets say you owned a car in desert camouflage colours, with dayglo orange wheels. You would definitely obscure
the plate, just in case there was another, untaxed, that had the same colour scheme, that some unscrupulous so & so
would drive about with your plates on.
No offence. Just having a laugh.
Paul G
[Edited on 8/8/16 by 907]
prawnabie
posted on 8/8/16 at 02:05 PM Reply With Quote
Another common reason is the vehicle has been repaired after an accident. More often than not the n/s airbags will punch a hole in the dash when they are deployed and a second had one is put in with the donor cars chassis number still on it.
SteveWalker
posted on 8/8/16 at 04:17 PM Reply With Quote
I'd go with the cloning reason. It's easy enough to get fake plates. Copy the VIN as well and it looks like a legit, taxes, insured and MOTed motor. If they've got contacts and can get the owner's details too, they can walk away from a police check with no problem.
coyoteboy
posted on 9/8/16 at 12:12 PM Reply With Quote
Yep, easy to clone if you have the time to put together a matching VIN and plates.
Covering it means that they at least can't easily get the two from one car.
I'm not sure how most things like speeding tickets stand up in court - there's no way the police can prove it wasn't a cloned car (without image of the driver), so the evidence is worthless. Yet still it stands.
