Pair of luke harnesses
garyo - 9/11/15 at 09:20 PM
I dont think these have had much use at all given how clean and free of grays they are, but probably too old to be fia approved. The approval code says 91013. Is that a date?
£40 collected from rg10 preferred , or postage possible.
Lukes
Lukes
MsD - 9/11/15 at 09:28 PM
Are these long enough to fit to a harness bar in a 'normal car'? Im after some for a clio.
Cheers, Mark.
Rossmcleod - 9/11/15 at 10:13 PM
A take there still good for the iva test
garyo - 9/11/15 at 10:24 PM
They may well be long enough. I'll check with the tape measure tomorrow and report back.
I've no idea re passing iva- what do they need for that?
garyo - 10/11/15 at 06:48 AM
They're e marked but I'm not sure of the exact date and don't know about IVA.
Th h he belts are 206cm from lap belt to the end of the strap. The mini strap with the mounting point is 15cm so that would give you even more length. If be amazed if that wasn't enough for a clio?
I'll give Mark first refusal as per your u2u mark- let me know.
Gary .
dmrider_10 - 10/11/15 at 11:44 AM
Ill give you £50 delivered? Thanks
garyo - 10/11/15 at 02:57 PM
Provisionally sold to MsD/Mark.
