Megasquirt Rolling Road at last
madteg - 21/6/11 at 06:47 PM
Had my car done at Advanced Motor Sport & Engineering yesterday and very happy with the results car drives so much better from 1000rpm to 3000rpm, gained 40BHP at that point and turbo no longer spikes like it used to so can get power down a lot better now. Only there for 1 hour at a cost of £90 worth every penny.
(Car is set up inside a wind tunnel instead of having fan on front of car it works great as i even got cold air through the inter cooler.) Sorry they are at silverstone.
Had to repeat post so everybody has seen it.
ashg - 21/6/11 at 08:11 PM
did they do it on a conventional rr or did they hook you up to those crazy wheels off the car dyno things? £90 seems pretty cheep.
make me consider driving up country just to see if they can get a little bit more out of mine.
madteg - 21/6/11 at 08:24 PM
Hooked it up to those crazy hook up boxes that go up to 2500BHP, When i turned ut there was a supra pushing 850BHP on th crazy boxes.
[Edited on 21/6/11 by madteg]
scoop - 21/6/11 at 08:49 PM
So what did yours make in the end?
Steve Lovelock - 21/6/11 at 09:15 PM
Thanks for you're persistence, I for one hadn't seen the initial post.
Does it look as if it could handle a set-up with all the queries that I have?
I haven't looked at the EGO settings yet.
