Hi, I'm currently trying to fit a type 9 to a VW TDI engine to go in a Mk1 Transit.
I was wondering if anyone on here knew of any engines which have a clutch disc as close to 227mm as possible to go on a ford 1"x 23 spline
shaft?
I've never mixed and matched bits like this before but if I end up with slightly less surface area between vw cover and ford plate, I guess it
means it just wont take quite so much torque?
Thanks,
Andrew
If you go onto http://www9.qha.com/uk/technical/qhcatalogues.htm
You can compare all the clutch friction plates availiable.
I had to use a 215mm friction plate (sierra) when I was looking for a 228mm to suit an Alfa pressure plate. With a light weight car its been no
problem. Dont be tempted to go even a couple of mm bigger . I bought a 230mm and it was too big.
Mondeo Mk1 1.6 and 1.8 petrol have 220mm plates with the same spline - QH part C1189AF
Maybe an option?
I bought a 228mm 1"x23 friction plate from National Clutches for £20. I think it's from a Focus diesel?
http://www.national-auto.co.uk/
but to be honest, I just phoned them up and told them what I wanted. They sent the plate to my closest dealer and I went along and bought it!
A quick peek through the catalogues:
228mm friction plates:
Focus DERV NCK 1055, NCK 1192.
Galaxy NCK 929, NCK 977
HTH
Hi,
Thanks for all the speedy replies, really helpful
Thank you
Andrew
Just be carful of the more modern clutches, often the spring face of the friction plate protrudes too far and may not clear. I could not use the Modeo
plate for that reason
Some are designed for pull clutch operation and not push
I think the problem with the gubbins protruding too far isn't model dependant but more the manufacturer of the clutch plate. When I spoke to the tech guy at National and told him what I wanted, he actually asked if there would be issues with the 'torque cage' or springs catching on the flywheel bolts or the clutch cover. I had the measurements to hand and he found me a remanufactured clutch to suit.
National were really helpful, I'm having one specially made up to fit, as none had the right thickness off the shelf.
Thanks for the recomendation!
Andrew, you owe me a pint.......
Next time I'm in Whitby!
Collecting it tommorow,
Thanks again
