Author: Subject: Drill or ream, what is the difference?
Steve Lovelock
posted on 22/8/10 at 07:35 AM Reply With Quote
Hello,
The chassis for my next project has been galvanised. I need to remove the coating from areas where some of the bushes and foot pedal bar etc. attach to it. Is there a difference between drilling these bores out or reaming them out? The pedal bar bore needs to be accurate to avoid play. I have a feeling that this question will expose a high degree of ignorance on my part so go easy on me please.
posted on 22/8/10 at 07:40 AM Reply With Quote
Try drilling a hole in a piece of metal similar to what you will be using and check the shape of the hole , it will be trapezodial (not sure of spelling) in other words a rounded triangle. Reaming should make the hole circular. HTH, Mel
NigeEss
posted on 22/8/10 at 07:42 AM Reply With Quote
Drilling is far less accurate and especially on larger holes can produce non round holes.
But as you are only removing soft zinc over a pre- formed hole a drill should be fine if you use the same size drill as hole.
Wheels244
posted on 22/8/10 at 07:44 AM Reply With Quote
Rusty is right.
Always use a reamer where accuracy is required.
Steve Lovelock
posted on 22/8/10 at 08:31 AM Reply With Quote
Thanks,
Can I use a reamer in a drill or hand tool?
Any idea of good places to buy them?
40inches
posted on 22/8/10 at 08:34 AM Reply With Quote
If you are simply drilling out pre drilled holes, just run a drill down them.
Reamers are precision ground and are expensive, and used to finish a pre bored hole to an exact size, usually for bores in bushes.
omega 24 v6
posted on 22/8/10 at 08:36 AM Reply With Quote
Drill a 1/2 inch hole in a piece of tin and just before the drill goes all the way through look at the hole shape. ( like rusty says).
A reamer has many lands ( edges) and as such keeps itself centred to the hole. Also it only cuts off a small amount of material and as such it is only used to finish off a hole size. It is very accurate.
[Edited on 22/8/10 by omega 24 v6]
madteg
posted on 22/8/10 at 08:54 AM Reply With Quote
Just a note do not turn a reamer backwards or try to take to much of as it will jam up, i would not use in a drill if it jams it will snap.
omega 24 v6
posted on 22/8/10 at 08:55 AM Reply With Quote
And use cutting oil
posted on 22/8/10 at 10:16 AM Reply With Quote
If you're just clearing a hole so that you can put a bolt through, use a drill bit. Don't use a reamer as they are quite expensive, easily spoiled and don't cut much material.
As said above - the reamer is used to finish off a drilled hole, to make it perfectly round (e.g. to take a shaft). If you have lots of different-sized holes to deal with, then drill bits will be much cheaper than a range of reamers!
Alan B
posted on 30/8/10 at 01:56 PM Reply With Quote
What may not be clear is that you can't use JUST a reamer...I know everyone says they are for enlarging an existing hole, but that is ALL they do...they have no ability to start a hole.
Confused but excited.
posted on 1/9/10 at 06:42 PM Reply With Quote
If your drill bits produce trapezoidal holes, try sharpening them properly.
omega 24 v6
posted on 1/9/10 at 10:10 PM Reply With Quote
By using this logic there would be no need for reamers as all drill would cut perfectly round holes.
omega 24 v6
