Author: Subject: Megajolt v4 Advice
ollie2910
posted on 29/10/11 at 02:52 PM Reply With Quote
Megajolt v4 Advice
Hi All
Been a while since I've managed to get onto the forum, but I was thinking of getting a megajolt bolted onto my v6 cosworth lump,
has anyone got any wise words as to weather this would be a good or bad idea??
Thanking you in advance...
Ollie
MakeEverything
posted on 29/10/11 at 02:59 PM Reply With Quote
Why not go for megasquirt and control the EFI as well? The EDIS 6 and coil packs would still be needed for either, so youll be more likely to get additional power from controlling the fuel as well.
Kindest Regards,
Richard.
big_wasa
posted on 29/10/11 at 03:09 PM Reply With Quote
you will need an edis 6 and they are rare
ollie2910
posted on 29/10/11 at 03:12 PM Reply With Quote
Luckily i have the Edis 6 already,, i have a ford baby Ecu in there at the moment, but im having al sorts of issues with it.
Ollie
AntonUK
posted on 29/10/11 at 03:29 PM Reply With Quote
I would defiantly look at a m'squirt instead... just disable the fueling part and run it Ing only
Lots more features to it even then than a MJ
ollie2910
posted on 31/10/11 at 04:36 PM Reply With Quote
Thanks for your advice,, dropped Phil a line at extraEFI, He should be able to point me to the correct M-Squirt..
NeilP
posted on 31/10/11 at 09:31 PM Reply With Quote
Ollie,
I have the BABY as well - I'm getting strange fuelling issues (still) - stuttering at higher revs in higher gears?...
What are you experiencing?
Cheers, Neil.
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
ollie2910
posted on 1/11/11 at 09:52 AM Reply With Quote
Neil
My problems have come from the initial wire up of the engine to the Baby. i'm afraid i have been in the dark a little since reaching this part of the build. (a handy ford mechanic would go down a treat) but many people have recommended going for the after market ecu, i think it may solve some problems (and many hours pulling my hair out).
Are you still running the fore runner to my BOB v6?
ollie
NeilP
posted on 1/11/11 at 07:20 PM Reply With Quote
Yep - I'm a BOA - doing OK even with a stutter!...
NeilP
posted on 1/11/11 at 07:21 PM Reply With Quote
Chippy (Ray) is in your area I think and he's running the cossie as well - He's a bit of a genuis so might be worth U2U-ing him...
N.
