<<  1    2  >>
Author: Subject: 4x4 donor..are all going to be heavy set ups
w.olly
posted on 4/3/12 at 12:09 PM Reply With Quote
Hi folks, i was looking into a ford V6 4x4 build, but as its going to be a bit on the heavy side i will give it a miss, thats if i ever get to start the build. So what other 4x4 donors can you suggest, A V engine would be nice if there is such thing as a light weight set up, but mainly a 4x4 is concern for my build.
IIRC there was a ford 1.8 4x4, or was it a 2.0?
I know there will be more weight with a 4x4 with the more running gear but i dont think it will be that much........or will it?
I did wonder of an MR2 donor to give a lively rear engine kit, i see they are cheap nowadays for the MK2, so if the 4x4 is a no go in the end i mite go MR2, but who does chassis plans for them?
W,olly
PSpirine
posted on 4/3/12 at 12:39 PM Reply With Quote
Subaru would be my choice.. a legacy or n/a impreza can be picked up for £300 - manual gearbox, nice flat boxer four engine and 4wd.
w.olly
posted on 4/3/12 at 01:15 PM Reply With Quote
OOoo, never thought of them, but why the N/A, i guess i would need to highly mod a locost chassis, even a haynes.
batteredoldsupersport
posted on 4/3/12 at 01:17 PM Reply With Quote
A mate drives a Golf 4x4, I think it's a 2.8, either V5 or V6. He likes it, having spent years in a Subaru he's a x4 convert
NigeEss
posted on 4/3/12 at 01:24 PM Reply With Quote
Being a Boxer the Scooby lump is too wide for a Locost type chassis.
w.olly
I just the love feel driving a 4x4, the reason to build a 4x4 locost. Is there any certain cars to avoid to use as a donor?
[Edited on 4/3/12 by w.olly]
NigeEss
posted on 4/3/12 at 01:41 PM Reply With Quote
Also bear in mind that most 4x4 cars have transverse engines, again too wide for a Sevenesque
application.
They would fit a mid-engine layout but getting the drive to the front would need some serious
thought.
Two bike engines as per the Tiger Z100WR maybe ?
Dave Ashurst
posted on 4/3/12 at 02:03 PM Reply With Quote
...also bear in mind that in a Subaru transmission system the engine overhangs the line of the front axle. Being a boxer the scooby engine is quite short and so isn't too much of an overhang.
The front wheels are driven from half shafts plugged directly into either side of the gearbox, rear of the clutch. That would be a challenge in a car that wants its engine sited behind the front wheels. (Esp if you used a longer engine.)
PSpirine
posted on 4/3/12 at 02:13 PM Reply With Quote
Didn't realise this was for a Seven type chassis!
Yes, subaru layout doesn't lend itself nicely to a Locost/Haynes etc.
If going for a locost type car, the sierra 4x4 running gear would be a good start. You could swap the engine out for a Suzuki engine and gearbox out of a Jimny (1.3, and interchangeable with swift GTI lumps I believe). The Jimny gearbox and transfer case aren't too heavy from what I understand and will have an output for the Ford's front diff.
No idea on gearing or physical size though!
Dave Ashurst
posted on 4/3/12 at 02:25 PM Reply With Quote
I don't think it is a 7-type necessarily.
bi22le
posted on 4/3/12 at 02:58 PM Reply With Quote
Was also my first thought when you said a V 4X4 drivetrain. There were limited Escort RS2000 4X4 (Mk4 style) but I love fords and would hate to think of a nice sample being gutted for its running gear.
Going down the VAG route you also have Audi Quottros, TT, A3, A4 . . . .
Please read my ring story:
plentywahalla
posted on 4/3/12 at 03:08 PM Reply With Quote
application.
thought.
It certainly used to be that twin engined set-ups were only road legal if they were geared together and drove through the same transmission.
I used to have an ex-army 'Twini Moke' that came from the mod auctions at Ruddington. It was not legal on the road unless one engine was immobilised.
I don't know if laws have been changed since. I know various hybrid drives are effectively twin engined, but they are 2 wheel drive through the same transmission. You are presumably trying to achieve a 4WD arrangement.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
posted on 4/3/12 at 03:36 PM Reply With Quote
Mate of mine has a Cossie powered 4x4 Dax that goes like the preverbal of a shiny shovel...
NigeEss
posted on 4/3/12 at 03:42 PM Reply With Quote
Well the Z100WR that Tiff Needell drove on Top Gear is indeed road legal and each engine has it's own transmission and diff.
posted on 4/3/12 at 04:03 PM Reply With Quote
Are you sure? I though that one had a box to link both drives and was RWD.
w.olly
posted on 4/3/12 at 05:18 PM Reply With Quote
Looks like i will be sticking to the standard MX5 and such, i have been looking at half built ones but then its on my mind how its well its been built, and then its the first big cash layout when i would be happier to spend and build as i go..........i will decide one day
Confused but excited.
posted on 4/3/12 at 05:36 PM Reply With Quote
My youngest had a Sierra XR4x4i that went like hell.
The little bugger sold it before I could get dibs on it.
It was a 2ltr straight four and would have been mental in a seven chassis.
w.olly
posted on 4/3/12 at 06:08 PM Reply With Quote
I knew they did something like that, my mate had one years ago, but it was a sapphire, it went like stink as was, if i could get one of them that would be the job
ali f27
posted on 4/3/12 at 06:53 PM Reply With Quote
Hi purdy built 1 from sierra 2.0 4x4 we put 2.3 in it out of scorpio got 200 bhp without to much trouble worked really well and not as hard as you think
posted on 4/3/12 at 07:32 PM Reply With Quote
Pretty sure he's right as Tiff Needell blew it up when one box changed gear and the other didn't. Russ Bost's Furore passed SVA with twin bike engines, one driving each rear wheel.
I've heard this story about twin engined cars a few times and no one has ever been able to point to any legislation so I believe it is simply one of those old wives' tales that refuses to die.
[Edited on 4/3/12 by MikeRJ]
Liam
posted on 6/3/12 at 08:15 PM Reply With Quote
The Tiger Z100 had two engines with outputs combined and RWD. The Z100WR had the front engine pointing the other way driving the front wheels through an upside-down Sierra rear diff for 4WD. You can tell them apart fairly easily as the 4WD with engines pointing opposite directions ends up with an exhaust manifold either side, whereas the 2WD has both engines pointing the same way and two full exhausts on the NS.
As for the OP, if you want to do something Seven shaped and 4WD you really dont have much choice other than the Ford running gear as you need the seperate front propshaft and diff so you can locate the engine and box independantly of the location of both axles. The extra weight (which includes heavier gearbox containing the centre diff, front prop, front diff and front driveshafts) is about 55 kg or so, so not too bad. You can use whatever engine you like if you are prepared to adapt it to the Ford gearbox. I certainly wouldn't recommend using the old Ford Cologne boat anchor unless maybe it was a 24V cossie. I'm using a Honda V6, although that will most probably change - my project has been mothballed for a good few years whilst other things are going on in my life and I'm currently in Norway for the forseable future. But when I resume I'm going to have more spare cash so I want to change a few things and do it right first time rather than cheap. First to be upgraded will be that old Honda V6 out of a Rover.
Have a look in my photo archive, and if you have any questions regarding making a 4WD give me a shout. A few others on here can help too, I'm sure.
[Edited on 6/3/12 by Liam]
NigeEss
posted on 6/3/12 at 08:58 PM Reply With Quote
Spot on Liam.
The only thing that physically links the Z100WR is the gear levers which can be locked together but generally are left
separate.
w.olly
posted on 1/4/12 at 02:57 PM Reply With Quote
Well, i have not put this off yet, i have a look at your Pics Liam, very nice build mate, impressed, now i will be going with the Ford Colonge route, but the 24v cossie as you suggest, i just think they are a great engine and have ran a few in the past, i ahve been looking at sierra donors, plenty of 1.6 and 1.8 etc about but not many 4x4, but still around at a fair price, £600ish for a scrapper, i wouldnt cut up a decent one, dont wnat to upset anyone by doing that
Liam, what chassis planes did you use if any, or what did you modify for the 4x4.
Another Q for anyone, is there any adaptors for a Ford G box to take a rover V8?????
wolly
[Edited on 1/4/12 by w.olly]
w.olly
posted on 8/4/12 at 02:10 PM Reply With Quote
What gear box did these run?
I am still on with this ford 4x4 donor idea and a 24V V6 cossie engine, if i am going to do this i mite aswell do it how i would like the first time, may take longer to build with the mods needed to whicj ever chassis i decide to build, but it will be worth it
Just cleaned out my work shop area, X aviary, not much room but looking forward to this build, sick of messing with rust on cars with the off roading lark.
bj928
posted on 8/4/12 at 02:52 PM Reply With Quote
if your going 24v cosworth u will need a 2.9 4x4 sierra, the older 2.8 4x4's had the type 9 4x4 box, the 2.9 had the MT75 box, u will need a v6 box as the bellhousings are not removable to change from a straght4 bellhousing, i have stuffed the 24v into loads of different vehicles and they are a great engine, but the type 9's don't last very long so go MT75
<<  1    2  >>
