<<  1    2    3  >>
Author: Subject: New Velocity XT owner
matt5964
posted on 27/7/13 at 09:10 AM Reply With Quote
Hello All,
I have Recently come from Bike's to my first Kit car
A Luego Velocity XT.2.0 ltr crated st170 lump
I cant seem to work out how to post up pic's?
Also I have a question regarding ground clearance as we are in and area were some roads are bumpy, we fitted a sump guard as we were not wanting to ground out the sump... good job we did as we have caught it a few times, so I have looked into a raceline sump etc.. the shallowest seem to be about 13cm in depth. However our sump on the car now is only 10cm and looks like a standard Zetec sump (again if someone can point me in the right direction I can put up some pics) we currently have 55mm ish Clarence from lowest point to ground!!
So I'm not sure weather to increase ride height, adj rebound/damping on Gaz collies, change the springs for different weight..[
Any help would be much appreciated
[Edited on 27/7/13 by matt5964]
jollygreengiant
posted on 27/7/13 at 10:41 AM Reply With Quote
Greetings and welcome.
Photo's. Click on photo archive (upper left), scroll down to upload photo's (there is a maximum size but cant remember what it is) and upload to site.
When posting open new post box and write what you want then there are several methods of showing your photo in post, I usually use the method : [ img ] (copy and past image location here) [ / img ] but without the spaces within the brackets. When viewing the image within your photo archive it will also show other ways to show in posts.
I hope this helps.
Also the lowest point on a car, other than deep sumps is usually the bell housing, so try and get some form of protection for the front bottom lip edge to stop that catching too.
jacko
posted on 27/7/13 at 10:43 AM Reply With Quote
luego velocity XT
luego velocity XT
There you go and wellcome to the best forum going
Jacko
Andybarbet
posted on 27/7/13 at 11:06 AM Reply With Quote
Very nice :-)
stevegough
posted on 27/7/13 at 11:46 AM Reply With Quote
Welcome to LCB, another velocity owner!
Another way of posting pics is hit the yellow pic button in the buttons above (when in edit mode) then paste in the link from your archive starting http and ending JPG.....like this: -
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
matt5964
posted on 27/7/13 at 01:28 PM Reply With Quote
ride height
ride height
ride height 2
ride height 2
sump depth
sump depth
Thanks for the reply's...I will get there in the end..lol
so from these pic's can anyone advise??
posted on 27/7/13 at 02:09 PM Reply With Quote
Could be my imagination but the bell housing looks very low which makes me suspect the engine mounts might be too low. Most sumps tend to be shortened to match the bell housing
matt5964
posted on 27/7/13 at 02:26 PM Reply With Quote
The sump shows no sign of shortening, and the guy we bought it off said the engine was as is came out of the create Looking at the engin mounts if they wee any higher then the top of the engine woul foul the nose cone neither would the bonnet fit. Am still con fused as to the sump being 10cm deep
It's a mt75 gearbox if that helps, will have to think about housing as you say
matt5964
posted on 28/7/13 at 06:09 PM Reply With Quote
Anyone have any ideas ?
paulf
posted on 28/7/13 at 08:42 PM Reply With Quote
You could gain about 25 mm by shortening the sump if still standard and below the bell housing there is no point in shortening it below the bell housing however.Is there no room at all for raising the engine? if there is you could put a couple of spacers under the engine mounts to gain a little more.
My car is a book built chassis which I think is 25 mm lower than the Luego chassis from the bottom rails to bonnet mounting height and I have about 75 mm ground clearance and have not had any problems with bottoming out.I did have to cut a small bit out of the nose cone to clear the engine which is mounted as high as possible.
Paul
Andybarbet
posted on 28/7/13 at 08:57 PM Reply With Quote
If it would fail the nosecone lifting the engine, would you be able to lift the engine if it was moved backwards ?
I am wondering if the engine would then sit in the bonnet bulge. Allowing a little more ground clearance ?
I dont have engine etc in my chassis yet so cant tell you whether I will have a similar issue but im using a type 9 gearbox mated to a silvertop zetec. Standard escort one piece ali sump at the moment but will probably need to shorten it for improved ground clearance.
Maybe the mt75 brings the engine forward more than the type 9 when using the original welded gearbox mount in the velocity chassis ?
[Edited on 28/7/13 by Andybarbet]
Andybarbet
posted on 28/7/13 at 09:11 PM Reply With Quote
Reading back your original question, you say the sump is only 10cm deep, im thinking that must be the steel part of the blacktop zetec sump ?
I think people have mentioned on here the need to still shorten the steel part & pickup pipe.
If I remember correctly the sump is in 2 parts & the top part is ali but looks like part of the engine, unlike the sump on my silvertop which is in 1 piece.
I reckon the raceline sump replaces both parts of yours so its 13cm but thats much shorter than yours if you account for both parts ?
Hope this makes sense ? If not then maybe someone could post up a picture of a standard blacktop sump so that you can compare it to yours.
Andybarbet
posted on 28/7/13 at 09:18 PM Reply With Quote
Found a blacktop zetec 2 piece sump picture here:
matt5964
posted on 29/7/13 at 05:50 AM Reply With Quote
Paul
Thanks I will have a look and see but don't think I can raise the engine with out a lot of bodywork chopping.
matt5964
posted on 29/7/13 at 05:52 AM Reply With Quote
There does seem to be some room in the engine bay from first look but as you say looks like from underneath the gearbox prevents the moving back of the engine
matt5964
posted on 29/7/13 at 05:53 AM Reply With Quote
Thanks this could be the issues, not realising the sump could be a 2 part one I will have a look when I get back tonight, I may still be on the path to getting a raceline sump...
matt5964
posted on 30/7/13 at 06:48 PM Reply With Quote
Defiantly a two part sump. It will leave the front of the gearbox as the lowest point. Will take some photo's and post to see if its all as I think.
matt5964
matt5964
posted on 13/8/13 at 06:47 PM Reply With Quote
well I have taken the plunge and ordered a raceline sump...it arrives on Friday so all being well I will get it fitted the week after, also ordered some Yellow Stuff pads only £95 for front and rear sets.
The Momo Team 280 is now on a NRG quick release and is a lovely bit of kit 0 play and now have a locking blank for when the wheel is off or car left for added security.
matt5964
posted on 16/2/14 at 10:26 AM Reply With Quote
Well, today is the start of the first real bit of work to the engine and first real span nearing I have ever done.. Engine is coming out ready for lots of upgrades now it's run in...going to get me some more ponies.
matt5964
posted on 16/2/14 at 07:45 PM Reply With Quote
Engine out with no dramas, drop it off at dunnel in the morning for all the work to be done
Andybarbet
posted on 16/2/14 at 11:54 PM Reply With Quote
Sounds good :-)
daveb666
posted on 19/2/14 at 09:49 AM Reply With Quote
details details!!
matt5964
posted on 21/2/14 at 11:21 PM Reply With Quote
Well, the head is getting ported flowed and polished, then some custom cams, competition springs retainers etc. bottom end bolts, lightened flywheel,crank pulley and balancing.
Then i have a dash2 to fit. Once run in its off to emerald for a remap and bigger injectors(not sure which ones yet, maybe let Dave suggest which to have)
Not sure if I need to do anything else at this point
posted on 22/2/14 at 02:16 PM Reply With Quote
Hope you've booked well in advance with Emerald ,well worth the wait.
<<  1    2    3  >>
