Author: Subject: Duratec omex 600 start up
gavin174
posted on 29/12/17 at 04:23 PM Reply With Quote
Good afternoon all
hope you had a good Christmas.
I am trying to help a friend finish a GBSC Zero running a 2.0 Duratec
2nd hand Omex 600 and self build loom,
AT power direct to head throttle bodies
we are having issues with the stat sync on the omex
ECU is seeing engine speed and timing errors counts up as you crank it...
stat sync clicks on every now and again for a few seconds and then goes off again.
we have read so many posts trying to find the solution, head is spinning now.
Any help gratefully received
thanks Gavin
Ian.C
posted on 29/12/17 at 06:51 PM Reply With Quote
Hi Gavin, I had the same issue with a n/a cosworth. I know there probably not available at this time of year but with one phone call and they had my engine running within minutes, make sure your sat in the car with the ecu communicating with your laptop up and running and i am confindent that they will get it running providing you have got everything set up, I have nothing but praise for the guys at omex their after sales service is next to non......I'm not on commision! Ian
gavin174
posted on 29/12/17 at 07:08 PM Reply With Quote
Thanks for the reply...
Omex are closed for holidays, and was hoping to get it sorted before i go back to work..
Cheers Gavin
