Zetec pulley help
YODI - 12/9/12 at 11:41 AM
Hi Guys
Im spending the day going over my new purchase, yesterday I noticed that the pulley (on the left in pic) wasn't sitting well as the bolt was at an angle to the pulley, well I tightened it up a touch and it wouldn't turn so I took it all off and the bearing doesn't go all the way through the centre so if you tighten it you're actually squashing it and it had a couple of odd washers placed behind it I assume for spacing.
What have you guys used, any ideas other than making up a fresh pulley?
Thanks, Yodi
degmwilliams - 12/9/12 at 11:56 AM
I don't see why you need the left pulley, you should be able to just buy a smaller belt unless that's the only way you can tension it of course.
whitestu - 12/9/12 at 12:06 PM
+1
Do away with it and get a shorter belt.
Stu
Xtreme Kermit - 12/9/12 at 12:08 PM
Hmmm - is there an alternator?
coozer - 12/9/12 at 12:16 PM
Bottom right hand corner....
As suggested just take the pulley off and use a shorter belt..
YODI - 12/9/12 at 12:47 PM
+1
Stu
You're right mate after posting I sat there and thought about it with a cup of tea, exactly what I've done just waiting for parts
and yes the alternator is there lol
mike.williams1 - 12/9/12 at 02:49 PM
Looking at the route of the belt if you remove the top pulley you won,t have enough belt to wrap around the water pump pulley.
femster87 - 12/9/12 at 02:55 PM
Thats exactly what I thought.
loggyboy - 12/9/12 at 02:57 PM
But its the left pulley thats being suggested to be removed, not the top one!?
YODI - 12/9/12 at 03:01 PM
Its the left pulley, which is already off, new belt fitted and running lovely
degmwilliams - 12/9/12 at 04:43 PM
Nice one, bet it looks alot better too.
YODI - 12/9/12 at 05:52 PM
I think so
Xtreme Kermit - 12/9/12 at 07:18 PM
D'oh! Seems obvious now, funny how you're biased by your own setup...
Edited to say, looks better now!
[Edited on 12/9/12 by Xtreme Kermit]
Schrodinger - 8/10/12 at 08:10 PM
You havn't got much contact now with the Aircon? pulley (pulley with three bolts)
YODI - 8/10/12 at 08:16 PM
Aircon????
The pulley with 3 bolts is the water pump, its been changed again slightly as the idler gave way due to bad design so I fitted a new one and bracket and there's enough contact in my opinion.
YODI - 8/10/12 at 08:17 PM
This is the new idler/bracket set up
degmwilliams - 8/10/12 at 08:21 PM
It doesn't take much driving on the water pump.
degmwilliams - 8/10/12 at 08:23 PM
Isn't there room for the alternator on the other side? I'm doing a tiger Avon but have mine on the other side.
YODI - 8/10/12 at 08:25 PM
Its something I am going to look into but its working well at the moment, I think I'd need a smaller alternator and still dont think it would fit with the throttle bodies
[Edited on 8/10/12 by YODI]
