I'm just fathoming out the cooling system on the ecoboost, which looks very similar to the duratec layout. From my pics of the factory car ive
seen I've come up with the diagram below. Can anyone see anything wrong with the layout? The oil cooler is one of the modine type ones on the
block. Credit to the caterham bloke who i've lifted some info from!
I think the ecoboost engines have two water thermostats. (may just be the 1l 3cyl though)
I recall they not also have an addional electric water pump?
Both just on the 1.0 3 cylinder as far as I'm aware. Should have said I'm using a 2.0 version. It's similar to the 2.0 duratec.
[Edited on 31/10/16 by sdh2903]
does it not have a water supply to and from the turbo?
should the stat feed the top of the radiator?
