posted on 30/6/11 at 08:03 PM |
Borg Warner 65 Auto Box to Manual
I've picked up a Formula 27 to play with over the summer. I'll move it on when my trike is ready.
It's an auto and uses the Rover SD1 running gear (V8 engine and Borg Warner 65 box).
The ONLY thing I might do is swap out the auto box for a manual. Can anyone recommend the easiest / cheapest solution should I go down this route?
PS - no piccies yet as I couldn't drive it home (the fueling is all over the place and it was struggling to top 40mph ).
It's Evolution Baby!
Simon
posted on 30/6/11 at 08:14 PM |
Remove auto box and all bits including flywheel/torque converter etc.
Remove old spigot bush, get the right one from Rimmers, also replace flywheel/clutch (careful when assembling engine/box as possible to dislodge
clutch slave/arm).
If using carbs, cut off/remove kickdown part of throttle linkage.
Mount clutch master cylinder and connect, bleed, connect prop and drive away
Something like that anyway
Simon
[Edited on 30/6/11 by Simon]
posted on 30/6/11 at 08:21 PM |
Cheers Simon... I perhaps didn't explain myself well (why change the habit of a lifetime ). I was looking for suggestions for which manual
box to use (LT77?) and if there is any box / clutch / flywheel / bellhousing combo that is more straightforward than others.
Benzine
posted on 30/6/11 at 08:26 PM |
Apparently it's interchangeable with the borg warner 35 box. The BW35 has it's own wiki page (can't find one for the 65) and it
lists cars that used the 35, so I'm guessing the manuals from the makes listed would fit? (Volvo is an option )
http://en.wikipedia.org/wiki/Borg-Warner_35_transmission
mcerd1
posted on 30/6/11 at 08:38 PM |
the usial 3 for the RV8 are the LT77, R380 and T5
the T5 was used by TVR and is pretty well bomb proof (but you'll pay for it)
it shouldn't be to hard to find an LT77 withouh breaking the bank
as far as I know the R380's were all in 4x4's as standard so need the transfer box swapped for a normal tail housing (no idea what this
involves, only ever seen them being sold as recon boxes)
[Edited on 30/6/2011 by mcerd1]
posted on 30/6/11 at 08:56 PM |
Cheers chaps!
PS - do you know anyone who can tune a 4-barrel carb Robert?
mark chandler
posted on 30/6/11 at 09:12 PM |
LT77s if you can find one, 77mm is the distance between the mainshaft and layshaft, the 's' is for stronger...
You will need to refettle the pedals, personally I would look to swap to a 4speed ZF auto, you will not change gear as fast !!!
atb Mark
mcerd1
posted on 30/6/11 at 09:32 PM |
sorry, don't know anyone up this way that I could recomend
there are a couple of rolling roads in town, but I've head mix reports....
I'm planning a run down to bogg bros in yorkshire to tune my bike carbs once the cars on the road (mainly becuase the roads in yorkshire were
fun )
posted on 30/6/11 at 09:41 PM |
Never mind Yorkshire, I'd not make it to East Linton with the carbs in the state they're in!
Simon
posted on 30/6/11 at 11:31 PM |
Put injection on it, you know it makes sense
I used LT77 - straight from an SD1.
Simon
