New Topic New Reply
Author: Subject: Newbie with questions....
ogausden
posted on 8/7/15 at 12:47 PM Reply With Quote
Have been thinking about a locost for a long time, but having hit my mid/late 30's and driving an auto every day, the locost idea is getting ever more appealing.
I'm pretty much set on a Haynes Roadster (home built chassis but taken to a good welder to finish), and I've narrowed my engines down to 1 of 2.
I'm looking at either a bmw 330 or a saab 2/2.3 turbo.
2 questions : has anyone on here done either engine (bmw block looks to be a tight fit?).
Is there anyone on here that lives near Ashford (Kent). I don't necessarily want to go out in a haynes, but sitting in a standard one could be useful to give an idea on if I need to widen it - I'm only 6ft tall, but have size 12 feet and I can't fit in a standard caterham!
Many thanks
Olly
[Edited on 8/7/15 by ogausden]
snapper
posted on 8/7/15 at 02:02 PM Reply With Quote
My first thought is that while it could be done (BMW 330) it's big and its heavy which rather misses the ponytail of a Haynes
Weight will also be mostly up front and will compromise handling
SAAB is smaller but has potential for lots of bhp
It is your car and you can fit what you like, you could increase the dimensions of the chassis like the McSorely dies with a +4 length and width and even height but go to big and it starts to look weird
I eat to survive
I drink to forget
inkafone
posted on 8/7/15 at 02:46 PM Reply With Quote
Big feet especially wide big feet (I'm size 13) are a problem plus a big engine with a big gearbox would make it even more of a pain. Either go wide bodied, mid-engined or bike engined with a narrowed tunnel. Big engines also produce a lot of heat so big sweaty swollen feet..................
adithorp
posted on 8/7/15 at 02:57 PM Reply With Quote
Almost anything is possible... but the further you go from the well traveled path of Ford 4pot engine/box, the harder it will get. There's less knowledge/experience to be shared around and drawn upon.
Why are you looking at those engines. Have you been under impressed by the performance of more standard engined 7's?
http://jpsc.org.uk/forum/
DapperRob
posted on 8/7/15 at 03:24 PM Reply With Quote
IIRC from my MIGweb days, the Saab engine shares a lot with the (GM...) Vauxhall C20XE / C20LET platform. The latter (turbo'd) is readily tuneable to the far side of 200bhp.
kj
posted on 8/7/15 at 05:15 PM Reply With Quote
Ash put a Saab engine in his
Think about it, think about it again and then do it.
ogausden
posted on 8/7/15 at 08:39 PM Reply With Quote
Ok, to answer some of the questions.....
Why those engines : 2 fold answer.
1) I'm a proper petrol head - I had a Mk1 Golf GTi at 18 (and I still have it), I've had various quick cars, and still do. Current fleet is 2 Saab 9-5 Aero estates, a 1.6 MK1 Golf GTi, a modified 1.8 Mk1 Golf GTi, a Toyota Prius (I know, I know, but it beats catching the train to London & is considerably cheaper), and the pride of the fleet a 4.2 TVR Cerbera. So I'm used to some fairly punchy cars, but I want something more raw than all of them, more rewarding, and something I have created/built.
2) The big BMW straight 6 (in 2.8 or 3.0 litre versions) is one of my favourite engines of all time. Very smooth, but with 200-230bhp its a proper monster when you want it to be (and they sound glorious !). The Saab engine (probably a B235R from a 9-5 aero) I know fairly well having rebuilt 2 now, and they are again very very smooth, but with 250bhp in stock form (going to 300 very easily), they are massively under rated bits of kit, and surprisingly civil off boost, and it doesn't get all out of hand when the boost does come in. A mechanic friend tried to convince me to use a 2.3 5-pot Volvo out a T5, and as much as a love the noise of a 5 pot (I owned a real Audi Quattro several years ago), something doesn't work for me.
Reading somewhere (don't think it was on here), although both the BM & Saab lumps are fairly meaty, people were fitting heavier (thicker walled) fuel tanks, more substantial diff's (not a bad idea considering the bhp/torque I'm looking at), and relocating batteries to the rear to get a bit more weight behind the seats.
I want to stay front engine, rather than mid (I prefer my limits being met slower, than the snap that typically happens with mid engine), and as much as I love the scream of a Jap sports bike, clutches are too small & fragile for my liking, and I'm a big fan of torque (although I have ruled out doing a TDi)
hizzi
posted on 8/7/15 at 09:14 PM Reply With Quote
i am building a mx5 based haynes at the moment using a flatpack kit from talon, have a look at my build thread, (hizzi) on the roadster builders forum.
there is another build on there using a bmw at the moment..
phil kit comes all precut readyt o weld and to be honest is almost as cheap as buying the steel yourself
Nickp
posted on 9/7/15 at 07:07 AM Reply With Quote
I'm putting the alloy blocked M52B28 BMW straight 6 in my Haynes. It does fit and I've got it right back against the bulkhead, due to it's nice short gearbox. This should give near as dammit 50/50 weight distribution, or so I've heard from previous M3 engined builds. Look where the 4 pot engines usually sit in a 'Seven' with the whole bellhousing forward of the bulkhead.
As for size, I'm 6ft1 and have size12's too. I can squeeze (litterally!!) into a narrow Westfield and the Haynes feels like a Limo in comparison!!
Link to my build- http://locostbuilders.co.uk/viewthread.php?tid=198679
New Topic New Reply
