New Topic New Reply
Author: Subject: Cheap Press?
AntonUK
posted on 18/8/16 at 09:54 AM Reply With Quote
Cheap Press?
Been looking at one of these lately for my garage.
any thoughts?
Hydraulic Workshop Press 12 Tonnes Tons Work Shop Garage Tool Metal Bending
Workshop press 12T
Economical 12 Ton Industrial Hydraulic Workshop Garage shop Press.
Used for parts straintening, bending and pressing.
Multi-position bed for work height adjustment.
Get your work done fast & efficiently with this perfect workshop press.
FEATURES:
-Repairing of electro motors and valves
-Installing & removing of pressure parts (gear wheels, bearings)
-Bending or straightening of metal
-Incl. hydraulic pump and 2x pressure plates
-Pressing plate adjustable in height
-Precise operation
TECHNICAL INFORMATION:
Dimensions (WxDxH): approx. 500 x 500 x 1320 mm
Width of working area: approx. 1 ft / 42 cm
Height of working area: approx. 0 to 1 ft / 0 to 75cm
Net weight: approx. 53 lbs / 43 kg
Maximum capacity. 12 t
Oil type required: hydraulic oil
DELIVERY:
1pcs, Workshop Press 12T incl. hydraulic pump and 2 pressure plates
Build Photos Here
loggyboy
posted on 18/8/16 at 10:06 AM Reply With Quote
Do you need 12 tonne?
would 6 do? 6 Ton Heavy Duty Hydraulic Workshop Garage Shop Standing Press 6000 kg
Mistral Motorsport
posted on 18/8/16 at 10:44 AM Reply With Quote
The seller is reliable and delivers very quickly I have bought a couple of major items from them recently.
Their prices for decent quality battery boost chargers are also very good and for OBD2 diagnostic items, for anybody thinking of buying it might be best to buy now before the pound goes completely round the u bend against the Euro.
907
posted on 18/8/16 at 10:55 AM Reply With Quote
Quote
FEATURES:
______________________________
End quote
So its good for bending....... and its good for straightening..... but will it bend things straight ?
On a more serious note;
There's things that a 12t will do, that a 6t won't, but not vice-versa.
Please don't ask why I own a six, and a ten.
Paul G
AntonUK
posted on 18/8/16 at 11:01 AM Reply With Quote
Thanks All,
Also spotted this one too
Its a little more expensive but a much bigger range. given I need to put some halfshaft bearings on (660mm) so the extra space will be of use.
HEAVY DUTY BLACK EDITION 12 TON WORKSHOP GARAGE HYDRAULIC UPRIGHT SHOP PRESS
Build Photos Here
sdh2903
posted on 18/8/16 at 11:03 AM Reply With Quote
Yes have the same one. It's paid for itself 5 times over. Yes it's cheap and yes the quality reflects it in places but it works. I've just pressed in 18 wishbone bushes in about half an hour. I've struggled with a couple of stubborn bearings using the 12t version so I wouldn't bother with a 6 ton.
motorcycle_mayhem
posted on 18/8/16 at 11:09 AM Reply With Quote
I have a Clarke 10-Ton, which has not yet been defeated by various Land Rover/Transit/Locost bearings, sleeves and bushes.
Experience dictates that I wouldn't necessarily go any higher, but I certainly wouldn't go any lower than 10-Ton.
Go 12, not 6.
sdh2903
posted on 18/8/16 at 11:11 AM Reply With Quote
Oh and it managed to defeat the seemingly impossible to split mx5 driveshaft and upright. Only just. but it did it.
posted on 18/8/16 at 01:03 PM Reply With Quote
I'd like to have the space for one (which I'd make use of) but kids bikes and scooters currently rule the garage space
micksalt
posted on 18/8/16 at 02:26 PM Reply With Quote
Part-exchange the children for the press?
I've got one of these cheaper presses. You have to be a bit inventive making up mandrels and support plates, but they work well.
posted on 18/8/16 at 02:39 PM Reply With Quote
Trust me if I could find a way of trading them in I would have done it by now
Slimy38
posted on 18/8/16 at 03:06 PM Reply With Quote
That's me sold!! If a tool can separate those then it must be made of kryptonite or something!
New Topic New Reply
