Toyota Beams 3sge and J160 Dimensions
nz_climber - 19/7/10 at 09:48 AM
Hopefully this might be helpful to some people out there!!
Here are a copule of PDF’s that I created with some general dimensions for the Altezza Beams 3sge engine and J160 6speed gearbox, also the dry sump system, sorry I don’t have a standard sump to measure anymore.
Here is a sample, download the PDF for the full size pictures and from different angles
http://aarons7.files.wordpress.com/2010/07/engine-top.pdf
http://aarons7.files.wordpress.com/2010/07/engine-lhs.pdf
http://aarons7.files.wordpress.com/2010/07/engine-rhs.pdf
http://aarons7.files.wordpress.com/2010/07/engine-front.pdf
http://aarons7.files.wordpress.com/2010/07/engine-rear.pdf
http://aarons7.files.wordpress.com/2010/07/dry-sump.pdf
http://aarons7.files.wordpress.com/2010/07/gearbox.pdf
I tried to be as accurate as possible with a tape measure, to the nearest 10mm or so.
kitcarcollection - 31/8/10 at 10:32 AM
I managed to put this 3sge blacktop engine in my MK Indy in a rather alternative setup.
You can see that here:
http://www.kitcarcollection.com/used-cars/raceindytoyota.php
To use it for normal sevens you will have to buy a drysump and cut a bit of the bottom of the gearbox. The altezza 6speed is nice but big
Also I would advise to not use the standard duo-mass flywheel as its 13kg instead of 5,9 for aftermarket ones.
To give an example from experience: It can be fitted in a RAW Striker too
coyoteboy - 31/8/10 at 11:39 AM
Oh I think I love you! That saves me measuring up my 3sgte for the most part, though my transmission is different and a few extremes are shifted, but the basic dims will save me a few hours with a tape!
nz_climber - 2/9/10 at 07:08 PM
No worries, glad I could help, the block dimensions will be the same, but the head on this version will be taller than the 3sgte.
