smart51
posted on 28/10/14 at 09:26 AM |
How do you remove grout?
We had our bathroom floor tiled about 8 years ago but recently, we've noticed water bubbling up through the grout when you stand on some of the
tiles. I want to remove the grout and redo it. How do you remove old grout without damaging the tiles? The grout gap is only about 2 or 3 mm.
theprisioner
posted on 28/10/14 at 09:37 AM |
There is a general purpose tool called by various names but originally called a Fein Multitool. It is an oscillating tool 20K rpm and takes a special
grout removal tool either made of Tungsten or Diamond. There are now dozens of manufacturers of such tools and the name of them and price varies
hugely. I no longer use a Fein but prefer the Bosch or Dewalt. (I am a retired odd job man)
Example:
eBay item number:390873033986
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
loggyboy
posted on 28/10/14 at 09:53 AM |
Same tool pops up in lidl/aldi for about £20
I would consider an exakt saw.
Mistral Motorsport
Davey D
posted on 28/10/14 at 10:19 AM |
Also you can get the Worx Sonicrafter from B&Q
pewe
posted on 28/10/14 at 10:35 AM |
If you're noticing water bubbling up when you stand on them there's likely to be a bigger job to do than simply replacing the grout
(unless you're after a quick fix).
If water has penetrated the tiles it will be sitting underneath.
Proper job would be to lift the tiles, dry out the sub-surface, re-bed the tiles and then re-grout.
Otherwise you risk all kinds of rot and nasties.
Cheers, Pewe10
posted on 28/10/14 at 12:16 PM |
Ditto what Pewe says, the water under the tiles needs sorting.
theprisioner
posted on 28/10/14 at 02:33 PM |
+1
LARKINGABOUT
posted on 28/10/14 at 07:17 PM |
+1 too. Water under the floor tiles is more than a grout issue and needs serious investigation
smart51
posted on 29/10/14 at 08:08 AM |
Thanks everyone. That souns like a great tool. I was planning to try and dry the floor with a hot air gun between the tiles. Is that not going to
be enough?
theprisioner
posted on 29/10/14 at 08:34 AM |
Once the moisture gets "locked in" you have to remove the tiles to dry it out and I hate to say this, depending on the substrate, more
remedial work may be required.
Non custom
posted on 29/10/14 at 09:21 AM |
Angle grinder
