Author: Subject: anyone ever used the Arduino for electronics based prototyping?
bi22le
posted on 22/8/14 at 07:18 PM Reply With Quote
Completely non car related.
I am currently working on a project with serious world wide conquering potential, honest!! I need to make a device that has temp sensing inputs as well as potentially humidity inputs. With the addition of timers I need it to jave switched outputs and a couple of low current resistance outputs. All simple stuff but I cant be arsed to build this and all of the sensors.
in maplins today for something unrelated I noticed Arduino kit. It looks like it should do the job. Has anyone ever used it for prototyping? How easy is it to program?
Is it sensible for the above OI management?
Any other comments?
Please read my ring story:
stevebubs
posted on 22/8/14 at 07:23 PM Reply With Quote
Arduino or raspberry Pi should be fine...or...new kid on the block...
http://www.spark.io
[Edited on 22/8/14 by stevebubs]
rf900rush
posted on 22/8/14 at 07:35 PM Reply With Quote
Hi
I have only used them twice, as I use Microchip's devices mainly.
Both my Arduino projects had all the hard work done by others.
One was a Temperature controller for a surface mount PCB oven, and the other a Video goggle head tracker.
I would do a good search for arduino projects similar to yours to see if some of the work has been done before.
Have a look at stores like https://www.sparkfun.com/ for add on boards / sensors.
You will of course new to program the device using a language like "C"
joneh
posted on 22/8/14 at 07:38 PM Reply With Quote
Yup, plenty of scripts available to download that'll probably do exactly what you want on the arduino site.
Easy and cheap.
jossey
Yes I prefer the pi but I use arduino when I need something a little more flexible. Contrary to popular belief and the stats the pi isn't as good due to power consumption. You should be fine with either but the pi will eat the battery more.
It's really can you do c++ or Linux will make the decision for you.
Dj
David Johnson
bi22le
posted on 22/8/14 at 09:57 PM Reply With Quote
I dont want to use a pi as I want something quick and simple.
I.was also hoping for a GI programming interface so I dont have to learn C.
any help regarding this?
tegwin
posted on 22/8/14 at 10:10 PM Reply With Quote
Theres a couple of flow-chart based GI writing tools for arduino. Ok to get the basics done. Can't remember their names but google should find them for you.
www.verticalhorizonsmedia.tv
Acc8braman
posted on 23/8/14 at 05:44 AM Reply With Quote
They are used quite a lot in the Marine fish keeping world. Go to http://www.ultimatereef.net/forums/ and go to Systems then lighting section. Or go to the sub forum for LEDS http://www.ultimatereef.net/forums/forumdisplay.php?f=717
Some of the guys building LED Lighting units are using them.
Awesome stuff.
Wish I still had mine.
[Edited on 23/8/14 by Acc8braman]
