Author: Subject: car port help
beaver34
posted on 23/6/15 at 09:23 PM Reply With Quote
car port help
hi,
as usual there is a wealth of knowledge on here so im after some it it please!
moved into our first house and it does have a couple of garages but as ive had more room ive purchased more cars so the mrs car now lives outside, its having a new roof tomorrow and part of the new car bargaining tool was that i would build a car port to keep the poor weather off her car.
now ive not built one before but was hoping i could fasten wooden uprights to the perimeter brick wall and then come off the garage with a sloping joists and polycarb roof
any thoughts?
pics
thanks
posted on 23/6/15 at 09:36 PM Reply With Quote
Sounds good. Don't drill too close to the top of the brickwork, it's easy to knock them loose. Check where rain will drain to.
owelly
posted on 23/6/15 at 10:25 PM Reply With Quote
Is there not any building regs that state you can't build within 1 meter of a boundary unless it's in fireproof material?
http://www.ppcmag.co.uk
posted on 23/6/15 at 10:38 PM Reply With Quote
I wouldn't bolt to the wall, I would use some posts and build a frame then put the polycarb under the gutter.
When I built mine behind my garage I used 4" fence posts and some 3x1 on its edge to support the poly, and just pushed it under the gutter, no problem for me.
beaver34
posted on 24/6/15 at 06:47 AM Reply With Quote
not sure where do i find these?
SJ
posted on 24/6/15 at 07:03 AM Reply With Quote
The timber in the fence already contravenes that one!
I think a car port has to meet the same regs as a shed so as long as it is under 2.5m on the boundary it should be OK. Worth checking though.
I used this Link for mine. Its really good VFM.
Have a look at the planning portal first for guidance.
Stu
[Edited on 24/6/15 by SJ]
hkp57
posted on 24/6/15 at 11:16 AM Reply With Quote
As above check planning requirements, once you have a front aspect and a boundary it changes the rules.
Check planning portal here
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
smart51
posted on 26/6/15 at 07:54 PM Reply With Quote
If a building is less than 15m2 and does not have sleeping accommodation, it can be built up to the boundary without needing to be built from non-combustible materials. Specifically about car ports:
"Building a new attached carport (open on at least two sides) would not normally require building regulations approval if it is less than 30 square metres in floor area." - http://www.planningportal.gov.uk/permission/commonprojects/outbuildings/
