Author: Subject: Powering 40 small LEDs
tegwin
posted on 5/2/16 at 06:35 PM Reply With Quote
Im having a bit of a brain fart and can't figure this out..
I have 40 LEDs current of 35ma, voltage of 3.4 being powered by a car battery. If I put three in series with a resistor several times it would work but I would be loosing a lot of power into the resistors. Does anyone know of a more elegant way of powering such a large array? (ideally dimmable).
www.verticalhorizonsmedia.tv
HowardB
posted on 5/2/16 at 06:39 PM Reply With Quote
Current limited pwm.
Pulse width modulation
Howard
hizzi
posted on 5/2/16 at 06:55 PM Reply With Quote
could you not use a string of them? you can buy a 15ft strip on ebay sticky backed that you cut to length
tegwin
posted on 5/2/16 at 06:56 PM Reply With Quote
I could but they would still need to be powered somehow?
posted on 5/2/16 at 07:02 PM Reply With Quote
12v LEDs either indivual or strips.
theconrodkid
posted on 5/2/16 at 07:41 PM Reply With Quote
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l2632.R2.TR5.TRC1.A0.H0.Xbuck+converter.TRS0&_nkw=buck+converter&_sacat=9 2074
who cares who wins
pass the pork pies
hizzi
posted on 5/2/16 at 08:15 PM Reply With Quote
what are you trying to do with the leds? are they for a car or other use. i use the 15ft strings cut to length and powered witha. wall wart for a model trainset, i use the same in the lockers on my landrover again easy as they are 12v
tegwin
posted on 5/2/16 at 08:20 PM Reply With Quote
They are going in the headlining of my van. Plan was to use single leds as stars rather than strips
posted on 5/2/16 at 08:21 PM Reply With Quote
You need to have constant current for 3 leds in series for 13 lots in parallel (39 in total). Plus the one extra ked
See here http://www.edn.com/design/led/4424539/Overcome-the-challenges-of-driving-parallel-LED-strings
A transistor for each series switched so the average current is within spec, get that wrong and all they will go pop.
You can buy led drivers but these are for higher current led emitters.
Do you need 40 leds or can you use brighter leds?
I suspect drop resistor will work out cheapest and simpkest but not the most efficient?
Re. 12 v leds, correct me but arent they regular leds with built in resistor?
coyoteboy
posted on 5/2/16 at 09:46 PM Reply With Quote
Yep, no such thing as a 12V LED (ok strictly some of the 100W LED chips can be driven at 12V but only for millisecond pulses)
There's no elegant way of driving that many LEDs in parallel (if you run constant current on a parallel bunch there's no control over which gets what current). By far the easiest and most cheap way is strings of 3 series with a current limiting resistor. You're dropping losing about 900mW on the whole system if you do it that way.
tegwin
posted on 5/2/16 at 09:54 PM Reply With Quote
Hmm ok. Well I'm sat on the floor wiring in the leds with resistors in sets of three. Decided on 30 as wiring 40 just seemed too much like effort on a Friday night!
Might get a voltage regulator and a pwm to change the brightness
posted on 6/2/16 at 08:06 AM Reply With Quote
Or use pwm to a switching device (e.g. transistor or open collector buffer) to have best of both worlds.... but it is extra complexity, get the pulse with wrong and you say bye byes to all the LEDs.
The switch could be more sophisticated and be current limiting but pushes complexity and cost so youve gone for the besy compromise.
