jacko
posted on 30/6/16 at 04:26 PM |
Trailer indespension unit bent
Hi All a mate of mine has asked me if i will have a go at straightening a arm on a unit
The thing is i don't want to strip the unit because i don't think i will get it back together
If i wrap wet rags round the part with the rubbers in do you think i could heat the arm to straighten it ?
This is what you get for over loading a trailer
thank's
jacko
gremlin1234
posted on 30/6/16 at 06:47 PM |
don't do it, just replace it. it wouldn't be as strong, he will overload it again, then blame you for the repair failing.
jacko
posted on 30/6/16 at 07:02 PM |
The Trailer will never go on the road it's only for moving horse sh*t from the stables to a sh*t pile
gremlin1234
posted on 30/6/16 at 07:11 PM |
then just weld it in position.
jacko
posted on 30/6/16 at 07:27 PM |
Thats what i will do if nothing else works but it would be nice with a bit of suspension
gremlin1234
posted on 30/6/16 at 07:40 PM |
a bit of suspension; let a few psi out of the tyre
owelly
posted on 30/6/16 at 11:32 PM |
The box-section trailing arm parts of my boat trailer Indespention units rotted away due to being dipped in the sea several times a week. I cut off
the box section and replaced them with some 3'x1' solid bar. I welded the stub axles to the new arms first, then welded the arms to the
bit surrounded by rubber. I did the welding in one go and lobbed the unit in a bucket of water. That would be about 16 years ago and they're
still going strong.
http://www.ppcmag.co.uk
jacko
posted on 1/7/16 at 02:36 PM |
Iv repaired the unit, in the end we just heated the bent arm and pulled it straight and cooled it down.
I was surprised the rubbers didn't catch fire well not much
jacko
