cut down disc hubs inside drums?
baz-R - 10/3/15 at 08:33 PM
has anyone managed to take some sierra disc hubs and flanges and fit them inside a drum brake setup? the caliper mount lugs would need choping off and the backplate center hole will need opening out 1-2mm
it looks like i will need to shim out the drum 1mm to change the offset diffrence but i will need to fit it all up first?
the idea is to have lobro shafts with drums
i want smaller wheels ,a better handbrake, less rear brake effort and less unsprung mass without having the hassle of hybrid or welded shafts
rdodger - 10/3/15 at 09:10 PM
Not done that
I have 13" wheels over wilwood handbrake calipers.
Lobro shafts with the bearing carrier ears chopped off and turned down a bit.
With AdiT's hand brake multiplier setup you can have it all but with discs!
baz-R - 1/5/15 at 06:13 PM
Well is all done and sorted now.
I have drums with bolt on drive shafts and cut down bearing carriers from a disc brake setup.
There's a difference in offset but I got it sorted
