Heat sleeve
Shooter63 - 25/11/18 at 06:21 PM
As I've top mounted my turbo the oil drain is running quite close to the manifold, I'm trying to find some heat sleeve to cover the hose with, so far the stuff I've found seems quite spend, I've thought about using exhaust wrap, what do you guys think
Shooter
obfripper - 25/11/18 at 07:59 PM
This is like oe fit sleeving, there's cheaper stuff from china if you can bear the wait.
https://www.ebay.co.uk/itm/Silicone-Fibreglass-Fire-Sleeving-Protective-Heat-Shield-Sleeve-Black-0-5m/192217278688
Dave
Shooter63 - 26/11/18 at 06:30 AM
Dave
Thanks Dave, it should do the job
jester - 27/11/18 at 01:47 PM
Or here fast shipping
https://www.merlinmotorsport.co.uk/s/heat-insulation/thermal-heat-sleeve-insulation
