wot kind of 0-60 times and top speed do u get out of the ford sierra 1.8 turbo diesel unit in the locost
whats the weight? the power? the torque?
cheers
fin
Kerb weight in lbs times 0.55 divided by the torque in ft/lbs = 0-60 in seconds
so 450kg = 990 kg
990 *.55 = 544.5
544.5/(say) 70ftlb = 8.1 sec
hmmm
Faster than that I would have thought.
Phil
A 1.8 TD Locost is going to weigh a little more than 450Kg!, more like 600Kg if you are careful with the weight
Originally posted by mdc124
so 450kg = 990 kg
990 *.55 = 544.5
hmmm
Try http://www.carfolio.com/specifications/models/id/?id=31966
It recons 112lbs/ft
So 650Kg = 1430Lbs
1430 x .55 = 786.5
divided by 112 = 7 seconds
Bugger me, why am I pissing around with a 2.0i Pinto!!!!!!!!!!!!!!!!
Ah, yes I remembered,
http://www.carfolio.com/specifications/models/id/?id=32230
600Kgs = 1320lbs
x 0.55 = 726
divided by 160 = 4.6 secs
Probably a bit optimistic, but WOW!!!
Mark could you possibly do me an estimate for my 0-60 using a 1.6 Pinto please? or anybody else?
james
Mark,
You want optimistic?
How's this:
Rover V8 - 198 ft/lb - weight 500 (or 600)kgs
1100 (1320) x .55 = 605/198
3.05 (3.66) secs
Will now have to turbo my bike!!
Wicked:-) (Uh)
Simon
600Kgs = 1320lbs
x 0.55 = 726
its just a rough estimate though that people are after isnt it?
I think Andre Jute's formulae assume the perfect axle ratio and perfect gear ratio's. The formula works more accuratly in the mid range of powers and
weights, I have tried it against a few production cars and it overestimates the acceleration of the high end cars and vice versa.
Has anyone got anything more in line with locost weights and usual power ranges?
There's so many variables (aerodynamics and fat bastardness of the driver/passenger for instance?) that isn't it just worth finishing what you've got,
then testing it.
We are sitting 4 inches from the ground with no real wind protection, so even at 20 it probably feels like double! (Haven't driven mine yet, so only
guessing, but have driven a single seater round Brands Hatch. probably only got to 50 and hardly changed gear and felt like Shuey).
I was a bit doubtfull about this formula, but having tried it on quite a few production cars it seems to be surprisingly accurate. It even predicted almost exactly the right 0-60 for a freinds TVR Chimera. It does seem to fall down a bit when 0-60 times go below about 4.5 seconds, as it dosen't take into account the traction problems that will be inevitable with that kind of power/weight.
Check out this site for details on performance measuring.
http://www.autospeed.com/A_1073/page1.html
Terry
Does anybody know the kind of 0-60 times and top speed a 1100cc GSXR powered locost would produce?
