Author: Subject: Zetec Sensor help
supercat
posted on 1/4/09 at 10:29 AM Reply With Quote
Zetec Sensor help
Does anyone know what this sensor location picks up (seems to be oil) and what thread it is? Its not the same thread as the oil sensors the inlet side of the block, want to see if I can use it for Oil Temp? Zetec Blacktop engine...
James
zetec_oil-2
zetec_oil-2
whitestu
posted on 1/4/09 at 10:32 AM Reply With Quote
I think that is for the Crank locking pin, used when changing cam belts / cheking valve timing.
Stu
stevec
posted on 1/4/09 at 11:03 AM Reply With Quote
It is the hole for the Timing pin for the crankshaft position. I believe it is m8x1.25 thread.
Steve.
r1_pete
posted on 1/4/09 at 11:06 AM Reply With Quote
Definately the crank TDC locking pin, you screw the pin in and it prevents the crank rotating clockwise past tdc.
Dusty
posted on 1/4/09 at 02:03 PM Reply With Quote
Fit with locktite. Lots of oil comes out fast if it comes loose and falls out at a trackday!!!!! Instant Billy-Nomates. I speak from experience.
