<<  1    2    3    4    5  >>
Author: Subject: ST170 VCT Delete Kit from the States
silky16v
posted on 6/1/13 at 05:57 PM Reply With Quote
Originally posted by Rob Allison
Very good that
well if it help's anyone else & the fact it can be done for around £100 i think its a good modification, just need to get engine back in car and get it mapped
Rob Allison
posted on 6/1/13 at 09:32 PM Reply With Quote
I will be good to see the dyno results. 200bhp is the target
silky16v
posted on 6/1/13 at 10:52 PM Reply With Quote
For me the target is 180bhp and a free revving engine all the way to 7250rpm
Anything above that will be a bonus fingers crossed it makes a little more though
silky16v
posted on 18/1/13 at 12:32 PM Reply With Quote
That's great. I'll try and get a cad drawing done
Did you manage to get this drawn out?
Rob Allison
posted on 18/1/13 at 04:39 PM Reply With Quote
Not yet. Been on to someone who makes the zetec pullys. He said its possible but may not be able to get a new centre bolt. He also asked how many were wanted. I guess that more would know the price down. Don't think he was interested in making the st pulley one of his normal sale items
silky16v
posted on 18/1/13 at 08:40 PM Reply With Quote
the fact the vct delete kit from the states is so cheap, its not worth getting 1 made unless its a batch lot
big_wasa
posted on 18/1/13 at 09:13 PM Reply With Quote
So any chance of floging the vtt solenoid for a few beer tokens please, I want one for my project. I would think you will be pluging it up ?
silky16v
posted on 18/1/13 at 10:20 PM Reply With Quote
As soon as i find a plug for the solenoid hole and I've tested my method for fixed timing has worked you can have it nothing
monck
posted on 20/1/13 at 11:42 AM Reply With Quote
Has anyone else got one in touch with this company about the delete kit apart from Silky16v i have tried there email 3 times and there Facebook and had no luck
[Edited on 20/1/13 by monck]
silky16v
posted on 20/1/13 at 12:56 PM Reply With Quote
Wired i'll see if I can try again for you
[Edited on 20/1/13 by silky16v]
monck
posted on 20/1/13 at 01:36 PM Reply With Quote
thanks
Rob Allison
posted on 20/1/13 at 02:14 PM Reply With Quote
Read on some US forums they are a bit hit and miss.
They also list on eBay but postage is too much that's on it.
silky16v
posted on 2/2/13 at 06:31 PM Reply With Quote
Today's update
Engine all back in and refitted with new mounts and some other little tweaks
Turned the key over a times to prime fuel system and to get oil back up in the engine
Here's the video of 1st start up
startup
Had to adjust tickover alittle higher once engine was warm and the water pipes had been connected, it has more intake noise as well
monck
posted on 2/2/13 at 07:03 PM Reply With Quote
Link don't seem to work ?
Good work tho
silky16v
posted on 3/2/13 at 02:17 PM Reply With Quote
Here is the video
monck
posted on 3/2/13 at 07:40 PM Reply With Quote
That vid works, it sounds well...
I got a delete kit from the states had no issues and was fast to get here once i got in contact so happy about that ..
Im going to copy your timing settings .. Are you planning on having it on the RR anytime soon?
Ryan
silky16v
posted on 3/2/13 at 09:25 PM Reply With Quote
Ryan
Yeah I'm going to take it to EFI parts to have the map altered, but I have innovate LC-1 I can data log with so can do the fuelling myself and I emailed omex for a base zetec timing map, I just need to compare that with the timing map that is on ECU already
monck
posted on 4/2/13 at 01:23 PM Reply With Quote
Just going of topic a second , in the vid i noticed you water temp gauges ect what make are they look like some ive seen on ebay wondered if they where any good ?
Ryan
posted on 4/2/13 at 01:34 PM Reply With Quote
Got them from here fella...
http://www.japshop.co.uk/acatalog/60mm-Gauges.html
silky16v
posted on 4/2/13 at 05:59 PM Reply With Quote
Ryan
As per Coozers reply he built the car, but can't fault the gauges I'm about to add an oil pressure gauge as well
monck
posted on 4/2/13 at 06:45 PM Reply With Quote
Thanks Coozer , ill let you know when the engine you sold me is in and running
I like the look of them gauges and after my blacktop threw blew id like to add an oil pressure gauge with the st170 engine ..
Thanks again silky16 ill be keeping my eye out for updates
silky16v
posted on 9/2/13 at 05:33 PM Reply With Quote
been working on car again today, and it's finally road ready, so took it out for a quick spin
engine is very very revvy, huge difference compared to pre VCT delete, hopefully i'll get some time to do some data logging and get the fueling adjusted
Rob Allison
posted on 12/2/13 at 11:35 PM Reply With Quote
Sounding good for the delete so far then
Rob Allison
posted on 24/2/13 at 02:43 PM Reply With Quote
Just ordered up a couple of Delete kits from Massive Speed. Easiest way to get hold of them is Facebook.
Ordered off there site via paypal. They will then send an altered postage amount. $17.95 for postage i think.
silky16v
posted on 7/3/13 at 12:11 PM Reply With Quote
Going for mapping this friday will post up results, once complete
<<  1    2    3    4    5  >>
