ST170 Zetec RWD Engine Brand new Build Please Read.
ST170 Zetec RWD rally spec engine, brand new build ready to fit. Spec below
Bored to 86mm 12-1 High compression wossner pistons, block bored pressure checked and decked, Williams steel rods, crank polished and checked, new
shells, new oil pump, RWD sump, head ported skimmed and polished by Andrew at ALD, CAT CAMS 2301013 spec with vernier pulleys, custom inlet with 2016
Honda fireblade 45mm tapered throttle bodies with bespoke plenum, WRC style timing belt tensioner, comes with exhaust manifold, flywheel, clutch,
brand new DTA S40 ECU and bespoke plug and play loom, high torque starter motor, race line water rail, alternator, crank breathers etc. Can be
seen/heard running as its still in my car. This engine has done less than 50 miles since build. For sale due to change of plans.
No time wasters this has cost a fortune to build, most of the parts were brand new except sump and flywheel.
Ready to fit and run.
£5250 ono.
Leeds area
[Edited on 4/7/17 by RWD Focus]
