starterman
posted on 7/11/17 at 08:49 PM |
Zetec inlet
Is there much or any difference between the inlet side of things on a 1.8 and a 2.0 black top Zetec?
Mike
big_wasa
posted on 7/11/17 at 08:57 PM |
Same bolt and port spacing so what bolts to one bolts to the other. Oem manifolds are often stamped 1.8/2.0.
For the Oem manifold they changed a little over the years. Silvertop had side fed injectors. Blacktop is standard Bosch end fed injectors
starterman
posted on 7/11/17 at 09:01 PM |
I knew if I waited long enough "Daddy, who knows far too much to be natural" would be along to enlighten me.
Thanks Wasa, much appreciated as always.
Mike
