Handbrake for reverse trike - suggestions.
dan8400 - 16/9/17 at 04:17 PM
Hi everyone
I am starting a reverse trike build based on a zx9r. I just wondered how I would do he handbrake. I either need some front calipers that can be made to use a handbrake or add a calipers to the bike rear wheel / disc.
Does anyone have any ideas?
I'm planning on using sierra front uprights and locost suspension.
Dan
jps - 16/9/17 at 06:24 PM
If it were shaft drive to the back wheel I'd say could you have something that locks the prop? Is there anything equivalent that can be done with a chain drive?
JAG - 16/9/17 at 08:29 PM
A reverse-trike would be light enough to use some rear axle calipers off a car with an integrated park brake - on the front axle.
Running a park-brake cable to each front wheel is simple enough.
That's what I would do
dan8400 - 16/9/17 at 08:32 PM
Thanks for that Justin.
Is there anything in the Ford 'parts bin' that will bolt straight on? Sierra rears?
Dan
bart - 16/9/17 at 10:27 PM
I'm using a small spot caliper from hi spec on mine , mounted separately on rear disk.
manual operation (law) enough to lock rear wheel.
craigdiver - 17/9/17 at 07:25 AM
My motorbike, an Aprilia Mana 850, has a handbrake fitted as standard. It has a second caliper mounted next to the main caliper.
JC - 17/9/17 at 07:34 AM
You might be able to use the Rally Design/VW calipers? On my midi they bolt straight on to the Fiesta upright I am using.
luke2152 - 17/9/17 at 07:54 AM
I've seen a show bike with a caliper operating on the back sprocket. It would be utterly ridiculous as a service brake due to all the chain lube but might be ok for a parking brake.
froggy - 17/9/17 at 08:56 AM
I've got a pair of new mechanical spot calipers that i don't need £50 plus postage
dan8400 - 17/9/17 at 09:02 AM
You have u2u Froggy.
Dan
blue2cv - 18/9/17 at 07:06 AM
Im sure i have a Wilwood spot caliper still boxed going spare too if anyone needs one
Angel Acevedo - 18/9/17 at 03:12 PM
Do you think the Cable and sleeves would be OK with all the Up-and-down and twisting required for steering?
I would think not.
The Cable sleeves on my donor are pretty stiff...
Maybe on a lighter car they are thinner and more flexible and more suitable.
