Bars Leaks
johnH20 - 20/5/18 at 11:01 AM
I have discovered my radiator has a minor leak, barely visible. I know this will mean a replacement rad at some time but I would rather put that off till the winter. In the 'old days' there was something called Bars Leaks that I remember using on an old Ford Anglia. Does this still exist and more importantly will it compromise the rest of my cooling system in any way?
johnH20 - 20/5/18 at 11:11 AM
Sort of answered my own question ( Google is your friend ). Yes it is available but some horror videos on Utube so I will not be using it. BE WARNED!
steve m - 20/5/18 at 03:56 PM
Pour a raw egg in the filler does exactly the same thing
steve
russbost - 20/5/18 at 04:23 PM
John
Use K seal, it's not destructive in terms of blocking waterways etc. like Bars is, & has an excellent reputation - the AA carry it as a roadside repair I believe!
Russ
johnH20 - 20/5/18 at 06:09 PM
Thanks Russ. I will give K Seal a try. By the way are you reading LB in Vietnam or are you back from your hols?
ian locostzx9rc2 - 20/5/18 at 06:22 PM
Plus one for k seal
russbost - 20/5/18 at 06:54 PM
I'm back!
907 - 21/5/18 at 06:08 AM
I wouldn't use any of those snake oils. We'll be cracking eggs into brake fluid reservoirs next.
I've just bought a rad for an MX5. £49 inc p&p. Why mess about?
Angel Acevedo - 21/5/18 at 07:26 PM
Where´s the leak...
In the old days you would strip a tube of its cooling fins and cut the tube near the leak (or at the leak) and fold it a couple of times with a needle nose plier.
Don´t know if it works with ali rads.
HTH
Schrodinger - 22/5/18 at 08:35 AM
I'm not sure where you are but http://www.sheldrakeandwells.co.uk/
in ipswich have repaired and modified rads for me in the past.
SPYDER - 22/5/18 at 09:06 AM
steve
Soon to feature in Heston Blumenthal's new book, " Roadside Cooking".
Page 7.
"Eggs a la Locost"
Cost to make, £250 of course!
