madrallysport
posted on 22/5/16 at 06:30 PM |
Chain driven diff
Anybody on here experience of such units, or a build or three I can read about using and mounting them, thinking about one for my car.
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
Phil_1471
posted on 22/5/16 at 07:21 PM |
What do you need to know? I run a chain diff on the Riot.
You can live in a car but can't rally a house
daniel mason
posted on 22/5/16 at 07:29 PM |
I've had them years. In 2 radicals and the Jedi. Strong units!
madrallysport
posted on 22/5/16 at 07:58 PM |
Just after a few pictures of how you have mounted them, distance from engine to unit, also do you move diff to tension chain or run a chain tensioner
daniel mason
posted on 22/5/16 at 08:13 PM |
I use shims.but some have tensioners.
I've not got any pics of the Jedi but look at empire racing cars gallery of how bill Chaplin mounts them. The Jedi and radical have a decent
distance between front and rear sprockets but the empires are very close as you'll see
daniel mason
posted on 22/5/16 at 08:14 PM |
https://www.facebook.com/Empireracingcars/?ref=ts&fref=ts
Ugg10
posted on 22/5/16 at 08:15 PM |
http://www.westwalestrikeshack.co.uk/chain-drive-differentials.php
Bit of info on here
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Phil_1471
posted on 22/5/16 at 08:49 PM |
Here's a couple of the Riot that I have on my phone, not quite as good as what will be on the Jedi ;-) but not had any issue to date, except
it's quite a short chain run so have to run a little slack (10-15mm).
