Author: Subject: Type 9 Reverse Switch Connector
mikeb
posted on 26/5/17 at 03:25 PM Reply With Quote
I'm onto almost the last wiring job, the reverse light. I don't have the two pin connector for the type 9 reverse switch. Any one any ideas where to get one or recommend something that will work?
Mike
[Edited on 26/5/17 by mikeb]
rash12
posted on 26/5/17 at 04:26 PM Reply With Quote
pricy but there are some on ebay 201928617651
Seller assumes all responsibility for this listing.
[Edited on 26/5/17 by rash12]
posted on 26/5/17 at 04:38 PM Reply With Quote
Would a connector from a Focus or Ka fit? Should be easy to find one of those.
stripe
posted on 26/5/17 at 05:01 PM Reply With Quote
the female bullet crimp connectors just fit over the pins
big-vee-twin
posted on 26/5/17 at 11:03 PM Reply With Quote
I soldered two wires onto the switch covered each with heat shrink insulation then used crimp bullet connectors
http://www.triangleltd.com
mikeb
posted on 27/5/17 at 06:05 AM Reply With Quote
Great thanks. I tried bullet connector over the terminals but didn't seem very good. Will try soldering
