New Topic New Reply
Author: Subject: Which oil for the sierra diff
badding
posted on 2/10/06 at 07:24 PM Reply With Quote
Hi folks,
I have a '89 3.62 non lsd diff form a ford sierra, does anabody know which oil and which amount I have to put in it...
Thx
StevieB
posted on 2/10/06 at 07:30 PM Reply With Quote
Haynes Manual says Hypoid gear oil, SAE 90EP
Guinness
posted on 2/10/06 at 07:38 PM Reply With Quote
Fill via the big allen key plug in the back, using a small diameter hose and a funnel.
Level is up to that hole. (Haynes says from dry between 0.8 and 0.9 litres).
Mike
[Edited on 2/10/06 by Guinness]
Pants On Fire
posted on 2/10/06 at 07:52 PM Reply With Quote
Mike
My Haynes manual says make a dip stick from some wire and fill to 10mm below the hole can't make that much difference can it?
Topical thread as I'm half way through replacing a drive shaft oil seal.
[Edited on 2/10/06 by Pants On Fire]
badding
posted on 2/10/06 at 07:57 PM Reply With Quote
Thanks guys for the reply..
Guinness
posted on 2/10/06 at 07:58 PM Reply With Quote
My Haynes manual says "Using a bit of bent wire as a dipstick, check that the oil is no more than 10mm (0.4in) below the plug hole".
I took that to mean that there is a minimum level, i.e. 10mm below hole, but that Haynes do not specificially state what the maximum is, but as it would be very difficult to get the oil to stay in above the point where you are filling it from, that level with that would do!
If I have overfilled my diff and bust it, I'll buy another from the local ford breakers.
Mike
Catpuss
posted on 2/10/06 at 09:31 PM Reply With Quote
On the "A race car is born" they say fill it up until oil starts dribbling out of the fill hole.
Pretty much the same rules as when filling crank cases of MZ 2 stroke bikes
chrisf
posted on 3/10/06 at 02:42 AM Reply With Quote
I used Redline Lightweight Shockproof gear oil--1 US quart
[Edited on 3/10/06 by chrisf]
robertst
posted on 3/10/06 at 01:23 PM Reply With Quote
my diff didnt come with the little rubber breathe hose its supposed to come with... it just has that hole. so when i fill it, do i have to plug the hole in anyway? what with?
Tom
tks
posted on 3/10/06 at 02:24 PM Reply With Quote
little hole
Well robert
i brought an complete back axle in "La Torre" for 120euro.. it was from a 2.0i 4x4
sow LSD 3,92unit..
it was cheaper then buying everything apart... as you can see in my pic archive its called donorparts.. you see the original "la torre" painting on...
Tks
think good before you guy is a wise advise!!
only the rearend is now 2 years later usefull to me!!
brakes wheren´t the same sow dumped and swapped for Wilwood ones..
propshaft was first modded (70buy+70mod) and finnaly trownaway for a new baileymorris unit with TRT..
Sow think twice
TKs
robertst
posted on 3/10/06 at 10:02 PM Reply With Quote
i just happened to buy the complete rear axle in that place! (La Torre)
it seems they emptied the oil, (just a bit left) and forgot to put the thingy back on?
the diff is in great shape though... just dont know what to do with this covering the hole thing..
Tom
DIY Si
posted on 3/10/06 at 10:05 PM Reply With Quote
If you mean the breather hole in the top, just jubilee clip a bit of pipe to it. It's not as if you intend spending much time upside down is it?! If you do, leaking gear oil is the least of your worries.
Sun Tzu, The Art of War
robertst
posted on 3/10/06 at 10:08 PM Reply With Quote
yeah, but my worries were focused more on oil coming out of that hole during cornering, or simply driving it as the diff is filled 10mm close to the hole... so i should obviously have something there shouldnt I?
just for simplicity... can i just plug the hole or does the diff have to have a vent opening?
Tom
chrisf
posted on 4/10/06 at 11:27 AM Reply With Quote
I've never has oil spill out of my breather. Yes, you need to have it.
--CHris
tks
posted on 4/10/06 at 12:53 PM Reply With Quote
Yes
the oil makes fumes and they need to be
extracted by that hole..
its not true that the level is 10mm below that hole! that hole is on the upside!
the diff should be as full as it can get by filling it with the torx bolt on the back!!
also that hole is baffled sow there won't come much oil out.
In fact from my diff there did come some oil out of it altough not the litle wich i put in later...
Did you buy to a LSD unit?? (from a 4x4 Sierra??)
see my pics in the archive
anyway i knew you brought it there!
Tks
schnelle bak
posted on 4/10/06 at 04:35 PM Reply With Quote
You mean the hole to fill te diff....you can order a new plug with your ford dealer.
I have too, because the plug would' t come lose, so my dad had to weld another bold to it...hope it comes lose know.
I thought it would be 15 min work to fill the diff, now i'm 2 days later and hove to order a new plug and seal the backplate from the diff again..
schnelle bak
posted on 4/10/06 at 08:08 PM Reply With Quote
diff pain in the arse
Finally got the bolt too fill the diff off, had to weld another bold on it just to get the damm thing off, I thought 15 min work to fill the diff, it took me 2 days Rescued attachment CIMG1561.JPG
New Topic New Reply
