ping
billydabarber - 13/9/14 at 10:15 AM
How do you ping someone on here and what does that do?
ian locostzx9rc2 - 13/9/14 at 04:25 PM
Uses the u2u button.
David Jenkins - 13/9/14 at 08:38 PM
'ping' is a command used when dealing with network issues - it's named after the ping you get from sonar. You send a signal to an IP address, and time how long it takes to receive a return message. For example, if I send
ping google.com
I get
PING google.com (212.56.71.144) 56(84) bytes of data.
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=1 ttl=60 time=14.2 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=2 ttl=60 time=12.8 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=3 ttl=60 time=12.5 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=4 ttl=60 time=12.5 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=5 ttl=60 time=13.8 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=6 ttl=60 time=12.5 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=7 ttl=60 time=12.5 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=8 ttl=60 time=13.3 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=9 ttl=60 time=12.8 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=10 ttl=60 time=12.8 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=11 ttl=60 time=13.5 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=12 ttl=60 time=13.7 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=13 ttl=60 time=13.0 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=14 ttl=60 time=12.8 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=15 ttl=60 time=12.6 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=16 ttl=60 time=12.8 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=17 ttl=60 time=12.8 ms
64 bytes from ggc02.plus.net (212.56.71.144): icmp_seq=18 ttl=60 time=12.8 ms
--- google.com ping statistics ---
18 packets transmitted, 18 received, 0% packet loss, time 17030ms
rtt min/avg/max/mdev = 12.583/13.044/14.209/0.491 ms
It's absolutely no use when using this forum though...
BigFaceDave - 13/9/14 at 08:48 PM
My microwave goes ping if that's any help?!
I'll get my coat....
[Edited on 13/9/14 by BigFaceDave]
jacko - 13/9/14 at 08:50 PM
ping pong
ping golf clubs
blakep82 - 13/9/14 at 09:00 PM
i don't think she's on here though...
nick205 - 13/9/14 at 09:32 PM
To give you a more constructive answer...you can send a U2U to another member which is a private message (often referred to as a PM on other forums). If you look at each members post you'll see the "U2U" button next to it. Ideal for communicating email and postal addresses when buying/selling or for conversations not suitable for the open forum.
That said, David Jenkins answer is what first came to mind when reading the thread title.
gingerprince - 13/9/14 at 10:27 PM
The machine that goes "PING!"
billydabarber - 14/9/14 at 09:07 AM
Hahaha thanks for replies :-)
blakep82 - 14/9/14 at 09:15 AM
So what was it you meant?
gingerprince - 14/9/14 at 09:19 AM
I suspect this...
Originally posted by aka Keith
Billy, I am just down the road in Crowthorne.
ping me on here or U2U me any questions you have. If you want a spin out, I can prob arrange.
cheers
Craig
[Edited on 14/9/14 by gingerprince]
