The window mechanisms on the TVR are way passed being usable....
Will I have any issues with MOT if there is no handle on the winder spindle and, for all intents and purposes the windows are then fixed closed?
You can open and close the windows using a combination of the winding handle and hands either side of the glass to raise/lower them... so I will have
to live with that until I can afford new window mechanics..
But is it legal to do that?
nope
Windows do not come into the MOT test.
They did on mine. The tester saw the CV boots had been changed and saw all the grease all over the underside of the car, he was pretty sure one would be knackered. He took it for a quick swing around the car park but because he couldn't wind the window down he couldn't tell which one and failed both!
I didn't mind this at all, although it probably not part of the test, because they were both rattling he was right to apply some common sense to it all. He had let lots of silly things go in the past so that was fair enough.
Thinking of "taking it for a spin"
what do you guys/gals do when you take your "interesting" cars in to be MOTd?
Do you stand over them and make sure they dont break/abuse the car or just leave them to it for a bit?
Im slightly nervous of the prospect of giving anyone the keys to such a fragile car!
The CV joints did need replacing, I have no problem with that. I was let off loads of by the book stuff before that. IMHO it was a common sense
ruling.
EDIT - the windows thing was a bit of a joke, I know they are not a test item. Seriously though, wouldn't you want a tester to fail stuff that
is bad rather than pass on a technicality?
[Edited on 1/2/09 by Mansfield]
Knocking Cv joints dont come into an mot. Only the boots split will fail.
As for the windows they are fine shut. Take the winders off though so he doesnt try to open them.
i don,t think the prob with your window/s is such a big problem that you think it is, the glass may have just slipped off it,s runner or a joint in
the winder mechanism has seized, i had a similar prob on my car, half an hour after taking the door card off the window worked a treat, a bit fiddly
as access is tight so small hands help.
andy
Originally posted by handyandy
i don,t think the prob with your window/s is such a big problem that you think it is, the glass may have just slipped off it,s runner or a joint in the winder mechanism has seized, i had a similar prob on my car, half an hour after taking the door card off the window worked a treat, a bit fiddly as access is tight so small hands help.
andy
Have you tried some silicone spray on the tracks. Can help a lot.
adrian
