hi,
my brake light switch does not seem long enough to screw into the m/c, can you get longer ones or anyone had this issue before at all?
here is a pic
They aren't designed to replace Banjo bolts you need to re-think your plumbing.
Normal ways of fitting a brake light pressure switch are direct into a spare port on the master cylinder or in to a 3 way or 4 way Tee
piece.
You can get bajo brake light switches though -
ebay
I've got one for a car I haven't finished building so can't comment on reliability etc.
Originally posted by lsdweb
You can get bajo brake light switches though - ebay
The lack of a hole in the switch would stop all flow in it too
