For Sale, F2000 reverse Gearbox with both prop shafts
This came out of a Fireblade powered Fisher Fury with an English Axle.
The props have the standard 109mm flanges with 90mm PCD
The front prop is 300-340mm
The Rear prop is 740-780mm
The reverse gearbox is 222mm from flange to flange
The working length from Gearbox to Diff is between 1282mm and 1322mm, it was 1310mm in the Fury.
All in good working order, I have only removed it as I am registered and looking to shed some weight.
Offers around £450, I am based in Ashford, Kent.
I am unable to work out how to paste pictures, if interested send me a U2U with an E-mail address and I will send pictures.
