Evening all,
I have for sale;
A zetec (silvertop) Alloy Inlet Manifold, for 38mm throttle bodies. They were made by the previous owner of the car, and had fitted GSXR tb's on
a 2.0l zetec.
£40??? +p+p
A mild steel exhaust flange for a zetec. Brand new from kit spares, cost me £15 +p+p.
£10 +p+p
A set of three Aero Catches. I wasn't given the keys for these when I collected the car, but I'm sure the locks can be changed if
required.
£10 +p+p
A water temperature adapter for 38mm hose, with temp adapter thread of M14x1.5. It has the temp sensor with it, part no FAE36050. On at 87, off at
82.
£5 +p+p
A standard sierra steering rack, has had a new lick of paint, but could do with some new bellows. No play in it though.
£10 +p+p
Cheers for looking,
Chris
[Edited on 20/5/13 by ChrisLeary]
ETA; The exhaust flange is mild steel, not stainless. Sorry for the confusion.
Is the flange defo stainless, if so il have it.
Yes please to the water temperature adaptor please! U2U on its way!
Yes, that's what they told me when I bought it.
Regards,
Chris
Regards,
Chris
I only ask as the website lists it as mild.
Make a small part damp and leave it over night, if it rusts its not stainless, if it doesn't then consider it sold!
Ah, it does, they definately told me it was stainless to go with the stainless manifold i bought.
Is there a quick test I can do to check?
Chris
Get a magnet, if it sticks to the flange then it's mild, if the magnet doesn't stick it's stainless.
(Some lower grade stainless the magnet will very slightly stick.)
Yes please for the aero catches, u2u in its way....
Update:
Temperature adapter SOLD
Aero Catches SOLD
Everything else still available.
Chris
The exhaust flange is mild steel. sorry for the wrong information.
Regards,
Chris
Bump
